FixYa.com
Tags:
Sony Plug-In Module DVD Drive
My Sony DVD RW stopped working.. with error...
posted by Sputnik on May 24, 2007
Hi!
In the Device Manager my SONY DVD RW AW-G170A
is marked with a yello "!". It is connected and
loads the DVD in the tray, but nothing else happens.
If I check it`s properties, the Device status is:
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
Device instance ID:
IDE\CDROMSONY_DVD_RW_AW-G170A____________________1.71____\5&154A5220&0&0.0.0
Same is for this one:
ZE3230H BKN262T SCSI CdRom Device
Device instance ID:
SCSI\CDROM&VEN_ZE3230H&PROD_BKN262T&REV_1.0\5&C16B70E&0&000
There is also a question mark at: Other devices...
Mass Storage Controller
This device is not configured correctly. (Code 1)
To reinstall the drivers for this device, click Reinstall Driver.
(I cannot find this)
I have XP64 on a Striker Extreme board with a QX6700...
Pleace help!
Comment by Sputnik, posted on May 24, 2007
Solution found!
Thanks to mark hopgood!
my no need to reboot solution
Monday, January 17, 2005 at 3:51 pm
Posted by mark hopgood (1 messages posted)
this worked for me with no need to reboot onwindows XP
start run regedit then open HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
delete the 2 filter entries (right click delete) then open control panel and in system, hardware tab,
device manager uninstall the cd drive that is giving you trouble then from the menu choose action,
scan for hardware changes and your cd should appear and be usable hope this helps
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 20, 2007
FixYa! (100)
Nits
Rank:Apprentice Apprentice
Rating: 100%, 5 votes
Hey its really worked
Thanks
Nitesh Oza
Rating Locked! (?) Sputnik has rated this solution as FixYa!
Can you Help with these DVD Drives problems?
DVD Drives
Cant play DVD video
I have a LG DVD writer model... Answer This...
DVD Drives
DVD drive not running specific...
my dvd drive, on a vista home... Answer This...
DVD Drives
SOLSTAR DVD PLAYER, DVD 15SS
The DVD Player did not have a... Answer This...
Sony (1-796-293-13) Plug-In Module DVD Drive
SONY DVD RW AW-Q170A not...
Hey...this is karma...i have a... Answer This...
storage
Hello Sir, Ple help me , i have... Answer This...
Repair Service
Find DVD Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
