Question about Konica Minolta magicolor 1690MF All-In-One Laser Printer
Konica Minolta magicolor 1690MF Link Magic states "The scanner is not connected."
WinXP connected via network. Worked in the past. Scans to Fax & to USB thumb drive using either multiple docs via ADF or single docs via flatbed. Reinstalled software (without uninstalling), but issue persists. Able to view web interface & to log in. Unable to scan to PC destination because after doc is scanned, scanner holds its position for about five minutes before beeping in error as it returns to its resting position--regardless of color or greyscale at 100% zoom & 150x150 dpi. (I've also tried larger dpi, different save locations for the resulting PDF, different file names, rebooting router, rebooting printer, rebooting computer, starting printer server, exploring firewall events, & reassembled printer). Printer has toner & adequate power.
Pookeybrain
  • 51 Answers
SOURCE: Unable to use printer over network with Server 2003 64Bit
Probably the best and easiest solution for your problem would be to buy an EDIMAX USB-Ethernet print server, or something equivalent. I have several of these running on the network at work. They're easy to setup and they work great.
Posted on Nov 11, 2007
Kevin Hayes
  • 167 Answers
SOURCE: Konica Minolta bizhub C250 Scanned files
Try using the Comapct PDF option as a file type.
This should be used if file size is a concern.
It applies a mathematical compression so will affect the quality of the scans very little.
Posted on Jul 07, 2008
  • 3 Answers
SOURCE: Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Posted on Aug 11, 2008
SOURCE: Konica Minolta C450 Scan function loses registered address book
this has happend before when creating a group in account track... check to see if you have a limited group on.... if so delete the group or change the limitations to (0)
Posted on Jan 02, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: I am new to the
When you press the scan button and get the screen where you are selecting the location to send to there is a tab at the lower right corner called "scan settings". You touch that, then on the next screen there is a small tab at the bottom center called "file name". Touch that and you can change the file name from the default KMBS...... to whatever you want.
Thank You for using Fixya! and please provide positive feedback if I was helpful.
Posted on Sep 08, 2010
Ow do i fix the error message MACHINE TROUBLE SERVICE CALL (0310) on my konica...
replace the print head. That's the part that houses the LASER. try this site for the part
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
if not try local Konica Minolta dealer
Sep 28, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Factory reset
Google software update.for it.or click on properties and select updates.
Dec 02, 2013 | Konica Minolta magicolor 1690MF All-In-One...
I have a konica minolta 1690mf. paper feed problem error 094
Transfer roller issue. the sponge looking roller across from the transfer belt.
Jun 26, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Konica minolta 1690mf process error belt clear by cover
KONICA MINOLTA 1690MF ERROR:
process error - belt (clear by cover)
SOLUTION: Open and close the scanner unit. Reseat the Image Unit and cycle the power to the machine. If the error persists and the machine is covered by warranty, a printer exchange is recommended.
KONICA MINOLTA SUPPORT PAGE:
https://kb.mykonicaminolta.com/selfservice_bus_anon/microsites/search.do?cmd=displayKC&docType=kc&externalId=TAD-doctad227704html0&sliceId=&docTypeID=DT_TAD_1_1&dialogID=10562139&stateId=1%200%2010556672
Feb 27, 2012 | Konica Minolta magicolor 1690MF All-In-One...
I have no driver and can't load a driver for My Mac OS X 10.6.6 for Konica Minolta magicolor 1690MF
Open this LINK, scroll down the page to the section called "Mac OSX 10.6.X - Drivers" and download your drivers. Hope this helps. Good Luck.
Thanks for using FixYa.
Mar 02, 2011 | Konica Minolta magicolor 1690MF All-In-One...
Konica Minolta magicolor 1690MF All-In-One Laser Printer Logo
426 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
