Question about Safe International Adg Sports Secure Vault front Load Electronic Safe
Reset the combination on a adg sports secure vault
Sports afield 6040 executive vault how to reset combination
Spot Afield safes default code is 1,2,3,4,5,6. Open the safe door, with door open lock the handle. This will let you have assess to your things if you have trouble while setting the codes. To change the code, press the * 6 times. You should hear a single beep and one flash from the LED, then enter the default code 1,2,3,4,5,6. Again you should hear one beep and see one flash. Enter the new code you would like to use ...lets say 6,5,4,3,2,1. You should hear one beep and see one flash. Enter the new code again 6,5,4,3,2,1. The code should now be set to 6,5,4,3,2,1. Try the new code and see if it unlocks the door. Also try the old code to make sure it no longer works.. If at any time during the process you hear 3 beeps and flashes something went wrong. You will need to start over.
Good Luck!!
Jun 30, 2014 | Other Sports Afield Executive Gun Safe...
Reset gun safe combination
I have a similar safe, although it is a different brand. I have a red button under the top of the safe, around where the battery's go in. I have to hold that button until I hear a beep and a red light flashes. Then I'm required to input the new combination. This may, or may not, work for you.
I recommend contacting the manufacturer and asking them.
Apr 28, 2013 | Safe International Adg Sports Secure Vault...
I forgot safewell vault's code but have the key the vault's no. 09002820
Write the Manufacturer and maybe try to list in a section of Fixya that is not a Cars and Trucks section.
Oct 17, 2012 | Cars & Trucks
What is the Vault ID?
ID Vault (Vault ID) provides complete protection against identity theft and fraud for your online accounts. It encrypts your passwords, usernames and credit card information securely on your PC. ID Vault logs you in without typing so you don't have to remember any passwords, and creates a secure connection between your PC and online accounts. Once you add your accounts, the ID Vault Secure View browser ensures that your online interactions with Bank, Brokerage, and Credit Card sites are safe. Automatic security and whitelist updates ensure that you are always dealing with legitimate Web sites. A single secure PIN is all you need to access all of your online accounts. ID Vault works with your security software for total protection.
Regards.
Aug 26, 2010 | Sylvania G-Netbook
I locked the toy vault and then i forgot the combination
If it's a toy, try taking off the hinges, you can always glue it back on later.
Apr 08, 2009 | Toys
Safe International Adg Sports Secure Vault front Load Electronic Safe Logo
307 people viewed this question
Top Safe International Home Security Experts
Computer Repairing
Computer Repairing
Theo Nikolaidis
Theo Nikolaidis
Are you a Safe International Home Security Expert? Answer questions, earn points and help others
