Question about Whirlpool WTW4800XQ Washer
I have a whirlpool washer that will not wash. When press the start button the motor moves then stops and the lid lock button comes on and starts blinking
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
The "lid latch" is faulty and need to be replaced. Here is the part you need to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 09, 2012
  • 43 Answers
SOURCE: whirlpool frontloader 6AWM8143
It's faulty contact the manufacturer or the seller
Posted on Feb 02, 2008
keithd2704
  • 56 Answers
SOURCE: whirlpool washer ultimate care II lsq8500JQ1 top...Problem
Ok folks to change the lid switch on these and many top loading Whirlpool, Maytag, Kenmore, etc is quite easy.
Steps to replace the lid switch:
1. Remove unit from AC.
2. Remove the loading door from the unit, or using some duct tape tape it closed.
3. Using a small flat bladed screwdriver find the 2 release catches on the front of the unit between the top cover and front panel. These are just snap claps to hold the top cover down. To release the top you will need to compress the latch using the screwdriver. Start with one side, then the other. Once you have released both clips the lid will lift up just like the hood of your car.
4. You will now be able to remove the lid switch from the unit.
5. Install the new switch and close the hood of the unit.
6. Test the repair by running the unit though a complete cycle.
A great place to order the replacement part for the unit is:
www.appliancepartspros.com
They ship same day on orders placed before 3pm EST. Overnight shipping is available, however I usually opt for the 2-3 day ground shipping and save the money.
If this switch replacement does not take care of the problem, you might need to replace the control board located under the front panel. This replacement is also very easy and takes about 10 min from start to finish.
Hope this helps everyone. Cheers,
Keith
Posted on Oct 21, 2008
aborcass
  • 2651 Answers
SOURCE: Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Posted on Nov 20, 2008
  • 1294 Answers
SOURCE: controls locked button on and other cycles light
Power shd be on. Press the "end of cycle" button on the right side for 3 seconds.
Posted on Mar 19, 2009
  • 464 Answers
SOURCE: Hello, my washer won't run! Whirlpool Cabrio
make sure the water inlet valve to the machine where the hoses hook up is in good working order. if you don't get water in the machine will lock you out.
Posted on Oct 16, 2009
Testimonial: "this seems like helpful advice on the surface, but after looking up the error code I'm receiving it is something to do with the motor rotor sensor..."
Whirlpool he washer-lid lock light flashing and lid locked. reset by using start/pause/ lock button. start washer-light comes on/sensing begins light starts flashing again and washer stops operating
LID LOCK LIGHT STAYS ON NO START:
Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
MACHINES SAIDS SENSING
When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
God is good and that's why I give free advice.
Dec 26, 2016 | Whirlpool Washing Machines
I have an error message f51 on my whirlpool cabrio washer model number WTW7600XW0, What is it and how can I fix this error on my own
F51 error code is a motor rotor position sensor failure or a lower harness problem. You need to check the motor in manual test mode, not automatic test mode. This will check the hall sensors and do a spin test: Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds.
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. During the 5 second wait time with 88 showing in the display, press the same button once. You should be in manual test mode. If the button is not pressed within 5 seconds, the automatic test mode begins. The Rotor Position Sensor uses Wash, Rinse, and Spin indicators to detect the three hall sensors. Console can have up to two of these indicators on at the same time when the tub is not moving. Open the lid and rotate the basket by hand. The Wash, Rinse, and Spin indicators should toggle on and off according to the direction the tub is being turned.
SPIN TEST: Make sure lid is down. Press and release: 2nd RINSE or EXTRA RINSE. The lid locks and the lid lock indicator turns on. Press and release; SPIN SPEED, WATER LEVEL, or LOAD SIZE. The motor/basket spins at 23 rpm. Press again, motor /basket spins at 530 rpm. Press again, motor/basket spins at 950 rpm. Press again and motor turns off.
Oct 24, 2014 | Washing Machines
What does error code f 51mean?
http://www.applianceblog.com/mainforums/threads/32879-Whirlpool-Cabrio-UL-F51-Error-Codes
Jul 27, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Wont drain and spin
Pl click if helped.
Apr 17, 2013 | Whirlpool WTW4950XW Washer
Whirlpool Wfw9050x will not advance to spin cycle
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 08, 2013 | Washing Machines
My whirlpool front loader wont final spin
Pl click if helped
Apr 05, 2013 | Whirlpool Washing Machines
The lid lock light won't stop blinking.
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
Power comes on and all lights come on, but the washer will not start the wash cycle. After the start button is pushed the lid lock will not lock.
That is why the washer won't start. Replace the lid lock. It is there to stop anyone from putting their hands inside of washer when it ia agitating, by stopping power to the motor.DO NOT try ANY attempts to mmake it work!!!! Injury may result
Feb 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer stopping mid-cycle
Push down on lid. You may have a bad lid switch. Start machine and press the switch down with something like a screwdriver and see if the motor runs.
Jul 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool WTW4800XQ Washer Logo
96 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
