Question about Goldstar R1003 Air Conditioner
Ice chunks I purchased this model a couple years ago...and from day one it would freeze up and you could hear chunks of ice being thrown around....this wasn't from dirty coils...it did it when it was new.......Last year I purchased a new window model, but I dropped it from the second story...so I just tried the gold star again last night...same thing... loudly throws chunks of ice around inside....why?????
  • norman medalle
    norman medalle Dec 09, 2007
    the room area is important and that depends on how large is your horsepower of the motor, the cooling system of the aircon has a censor for automatically shuts down the thermostat in order to prevent from exceeding cooling temperature meaning the ice stage, this will only happen when your airconditioner is low in horsepower but your area is big, minimized your area by putting a division curtain in your room or you can transfer to a smaller room.
Freeon problem or dirty filter
Posted on May 26, 2007
Top half of my refrigerator and freezer not as cold as it should be
Make sure there isn't anything blocking the cooling coils GE Side by Side Refrigerator GSS25JFMC Service Manual in PDF format... You can purchase a service manual from here.
Jun 26, 2017 | GE Refrigerators
My weber genesis silver-b (sku # 218446) is 11 years old and has this "peeling problem". Is anyone "sure" that it isn't "paint/enamel" that is peeling on a model that was...
I'ts the same today as it was back then. They still use porcelain enamel. Not paint. A couple of things that could ease your mind. Paint has like a kerosene smell to it. Also, drop a chunk in water for a few days, paint will not dissolve in water.
Jan 18, 2011 | Weber Genesis Silver C Grill
I have an old Frigidaire refrigeator/freezer, freezer on top. Model # FRT18TJHWO. It say manufactured 06-00. I presume that means June of 2000. I have had this for almost two years. A friend gave it...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 21, 2010 | Frigidaire Refrigerators
Icemaker makes Ice But doesn't dispense it.
Had same problem. Looked everywhere and found no solution i'm a not a repairman...they probably do not want to post so they can make 150 for a repair visit. At least try this first it may save you $$. Remove ice bucket from freezer. Remove 2 screws @ auger...remove cover and auger ....remove spring and large hex shaped shaft. heat the large shaft end with a torch and put it back in hot side toward motor until the motor end is not frozen. No torch you can use hot water...but that may freeze again.
This was happing because my flap to the ice was not closing all the way .
Manual for parts can be found here it shows ice maker parts on page 7.
Good Luck Kono
Aug 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker not dumping as frequently and cubes freezing one large chunk
The first thing I would check is the cleanliness of the condenser coil under the fridge. Make sure the fan under there is running, and that the coil is clear of dust. The ice maker requires 15 degrees for a period of time before it will make ice and dump. If the temp in the freezer is colder than this, then it is likely the ice maker needs replaced. They can be replaced fairly easily with just a couple tools. (1/4" nut driver and a flat screw driver). There is a plug where it plugs into the freezer side wall, and a bent tube that supplies water to the tray. If not sure what to do, have a service tech look at it.
May 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator is making a loid noise
** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
Mar 10, 2008 | Refrigerators
Freezer makes ice but has trouble dispensing it
are you still making ice in the icemaker?? if so then you most likely have a bad water inlet valve (back of unit right side behind the panel) The crappy thing is the icemaker and the water are on what is called a dual valve you have to replace the whole thing.. to test this you will need to sw the wires if you want to get into this let me know
Jan 17, 2008 | GE GSS25JEMWW Side by Side
Air conditioner
If the air flow is restricted or partially blocked (dirty cooling fins, filter etc), ice will form inside becaue the air stays in ithe cooling coil or fils for a long period of time. Lack of freon will not cause Ice formation because there is not enough cooling power.
May 24, 2007 | Goldstar R1003 Air Conditioner
Goldstar R1003 Air Conditioner Logo
241 people viewed this question
Top Goldstar Heating & Cooling Experts
Bill Long
Jim Goldsmith
Jim Goldsmith
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
