Behringer Eurolive model psu5 mains- in B215A/b212A part.
It,s a part i need in the Behringer Eurolive Part model # is PSU5
2 Suggested Answers
  • 5603 Answers
SOURCE: The 1/4
I have seen some of the 1/4 inch jacks that had the mounting nut overtightened and it resulted in the riveting of the threaded part to the metal where the wires connect being stretched to the point the riveting came loose, breaking the contact.
The only way to know is to open the unit. Some of the board mounted "plastic" wonder jacks one can't even see without unsoldering them from the circuit boards.
When replacing do NOT overtighten the mounting nut !!!
Posted on Jun 18, 2010
Remove woofer from behringer B215A
you want a woofer replacement? ... it's possible but you need to put whole your speakersystem in a program and the change you get the values you want is slittleeee. No if you need to ask if you have to change.... noooooooo. It's to complicated and only can ve done by peoples with real knowledge....
Apr 05, 2014 | Behringer Eurolive B212A Speaker
Tda7293 IC in behringer b215a keeps blowing, whats the cause?
Problem in the part of the power supply that feeds the tweeter amp. Fix the power supply and epoxy the board where it needs to be epoxy. Best of Luck! Serge Lavallee.
Dec 19, 2013 | Behringer Eurolive B212A Speaker
Diaphragm replacement parts
Hi
Here's the list of authorized Behringer dealers which should be able to help you out.
-Steve
Find Service Center
Nov 14, 2013 | Behringer Eurolive B212A Speaker
Behringer monitor lost treble
First and formost check the connections and ensure no stray strands between cables are touching, also the surface of the speaker is not been damaged
Jan 22, 2013 | Behringer Eurolive B212A Speaker
I installed a Q05-19700-00476 input PCBA for B215A componant. when I connect to the tweeter it blows it please help.
Certainly your hf driver is getting amp rail voltage, this is why tweeter blows, disconnect tweeter and with the unit powered on check the tweeter leads with a voltmeter and let me know the readings, but surely will be dc voltage...
Jan 02, 2013 | Behringer Eurolive B212A Speaker
I want to order a new volume pot for my Eurolive B215A powered speaker directly from Behringer, then fit it myself. Who do I contact to order the part?
Lots of luck. Behringer no longer sells direct. Fullcompass.com is their parts distributor. If they don't have it in stock, it takes months... I have had an order in for 6 months now. The procedure is you call Behringer at 1-425-672-0816 to get a part number and an incident type number. Then call Fullcompass and order the part at 1-800-356-5844 and tell them you need Behringer part. IF they have it in stock, then you are lucky.
May 18, 2011 | Behringer PA speaker Eurolive B212A
Behringer B215A replaced volume level knob does not respond.
You DON'T replace the board. If it is cracked, you bridge insulated wires around the cracks and epoxy them down.
Often the pads break from the traces near the pots. Look for a small crack between the pad of the pot and the circuit trace leaving it. Common problem.
Feb 09, 2010 | Behringer Eurolive B212A Speaker
Clip light
It sounds like one side of the power amp has shorted. May be hazardous to the speaker so best take it to a shop for repair. If speaker stills sounds OK, probably the clip detector transistors have failed.
Nov 08, 2009 | Behringer Eurolive B212A Speaker
114 people viewed this question
 Grubhead
Grubhead
