Question about HP Compaq Presario C304NR Notebook
Compaq wont Boot
The other day my son said that the power supply on the computer stopped working. The light would not come on and stay on. It seemed as though it may have shorted out.
He said he was able to boot it up for a short amount of time off the battery but it went in to the factory restore and then it shut down. I went and got a new power supply and all that happens is the power button keeps flashing rapidly and so does the lightning bolt on the front of the computer. The computer will not boot. I read that a gentleman had the same problem as what I am having and he replaced the Motherboard and that did not solve the problem. If it is not the Motherboard what else could it be?
  • powerdia Jan 05, 2009
    Would i be better off just getting a new laptop. I only paid 350.00 for this one. and it lasted me 3 years
  • bruced373 Feb 08, 2009
    My problem is that I think my battery wet bad and caused my charger to fail. I purchased a new charger and got a different battery. When I plug in the ac charger the charge light blinks. If I push the power button it also blinks and the computer will not turn on. Any help with the blinking light would be appreciated.
  • HP Master
  • 19,396 Answers
Apart that replacing the motherboard on a laptop is a difficult and expensive operation, component inside must be tested, as the problem is not necessarily the motherboard.
Try first starting the laptop without the battery, and only power adapter.
If it still does not start, and the AC charger has the right voltage (the one written +- .5 on reading) the laptop must be taken apart and tested.
The most likely is that the AC socket on motherboard had shorted or another component near the socket had blown because of the original accident.
Posted on Jan 05, 2009
I have a Compaq Presario SR2010NX that will not boot. When I plug in the power cable, a green light blinks at the back of the tower on the power supply. I was given the desktop in mint condition, which...
your power supply is bad. the blinking light means there is a failed component in the power supply. replace the power supply and you will be good to go. around 60 dollars at any computer place. please rate me thank you.
Jan 04, 2011 | HP Compaq Presario SR2010NX PC Desktop
I cannot seem to get this unit to boot up. There is a blank screen, power light, green cord light, orange battery light and nothing else. This unit belongs to my son, so I am only a little familiar with...
My Friend ,
Please Do these steps to boot up :-
1.Keep tabbing the f2 button on the keyboard till u get the bios screen.
2.Now here you need to go to the boot sequence and then select the boot sequence to Hard drive.
3.If this is ok then you need to tab the f8 key and boot the computer in safe mode .
4.Restart the computer.
Dec 12, 2010 | Toshiba NB205-N210 Netbook
Wont start power supply binks
What do u mean u unplug the motherboard...?
May 27, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
My gateway 700 xl doesnt boot
Unplug the power from you 700xl and from you monitor. Try removing the cmos battery and reinstalling it. Then, plug everything back in and try restarting. If it continues to give you the yellow light, you may need to replace the CMOS battery, especially if it is more than two years old.
Another thing to consider is if your power supply is underpowered for the number of external devices you have plugged into it (i.e., cd, dvd, external hard drives, printers, pci cards, etc). Gateway installed very low powered power supplies in their 700xl desktop computers. Usually only around 250 watts maximum.
If you are replacing the power supply with another 250 watt maximum power supply, and you have a lot of external devices plugged in, you may need at least a 350 watt power supply....if your CMOS battery is not the problem.
Nov 06, 2008 | Gateway 700 XL PC Desktop
My son changed towers and upgraded to another power supply
How long have you waited for it to boot up? Sometimes I have seen it sit on the logo for like 10 minutes thinking about the boot configuration. Also you might change out your hard drives and cd's and DVD's and check your jumper settings on all of them to see if any conflict with each other.
Jul 29, 2008 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Wont start up
my wife has a presario that had a similar problem - it would boot up, then immediately shut down. I took off the side plate and blew off some of the dust inside. that worked for a couple of days then the symptoms returned. I took it apart again but this time I removed the cpu fan and the cpu heat sink. I cleaned all the **** off the fan and the heat sink and replaced it. this time it stayed on. I checked out the power supply. compaq installed a very cheap power supply - only 250 watts. a replacement power supply for the same machine but with an output of 300 watts is available. as soon as I can scrape up the change, I'm gonna change the PS
Jun 11, 2008 | Compaq Presario 5000 PC Desktop
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
Wont stay on
does the game still boot check power supply or motherboard
Dec 23, 2007 | Sony PlayStation 2 Slimline Console
Boot up problem
It is possibly the RAM it may have ceased. Look at it underneath held in by two screws. Take it out and examine it then put it back. The motherboard seems ok because you said the lights are lighting up. Sometimes the ram can stop even the bios and nothing can boot up.
Oct 03, 2007 | Compaq Evo Notebook N115
HP Compaq Presario C304NR Notebook Logo
172 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
