Question about GE Profile JGSP48 Gas Kitchen Range
Model jgb900wef1ww GE Profile gas kitchen range cannot hold a set temperature while baking.
If you reset the temperature it will start to heat back up but once it hits the desired temp it starts to cool despite the screen showing the set temperature holding. Whats wrong?
SOURCE: GE Profile XL44 range
I think it's the ignitor.   Ours has been doing a very slow lighting for quite a while.  I found if I did a cleaning cycle it seems to work a little better... otherwise a new ignitor  ( Ours is gas )...  now it is flashing the probe and bake lights alternately and will not turn the oven on at all....  not so impressed at this point.....
Posted on Oct 15, 2007
SOURCE: Buttons on Control Panel not working for my GE Profile Gas Range
Anyone has any information as to how to fix my describe problem with GE Profile Gas Range I have.
Thanks
Posted on Mar 17, 2008
  • 23 Answers
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
VtToolMan
  • 704 Answers
SOURCE: Bake does not work but broiler does.
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
The reason that the temp display reverts to 100 degrees is because that is the lowest default temp setting for the display and until the oven temp actually starts to increase, it won't change. So the temp display is working correctly for the BAKE function.
Here's a line drawing showing the part you may need. Ignitor Part # WB13T10045. The good news is that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one. These aren't cheap at $91 bucks, but you can shop around the web for a better price if you determine you need one.
Sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JGS905SEK1SS&productCategoryId=0124250&brandId=3272&modelName=GAS-RANGE&diagramPageId=00001&componentDescription=GAS%20&%20BURNER%20PARTS&documentId=G6090295&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you out and remember to disconnect the oven from the electric power before performing any repair work. Best regards!
Posted on Aug 01, 2009
SOURCE: my GE Profile Gas range JGSP48 will not cook on
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list.
Posted on Jul 15, 2010
Why t takes long time for oven to heat up?
Does the oven actually heat up with the temperature more than 100 or does it just stay at 100? Alternatively, when you open the oven can you see the orange glow of the flame through the vents in the bottom of the oven and hear the gas hissing?
Aug 18, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE XL44 Self-Cleaning Gas oven heats up but is about 125-130 degrees cooler than what it is set for.
To Adjust the Thermostat
  1. Touch the BROIL HI/LO and BAKE pads at the same time for 3 seconds until the display shows SF.
  2. Touch the BAKE pad. A two digit number shows in the display.
  3. Touch BAKE again to alternate between increasing and decreasing the oven temperature.
  4. The oven temperature can be adjusted up to (+) 35°F (19°C) hotter or (-) 35°F (19°C) cooler. Touch the number pads the same way you read them. For example, to change the oven temperature 15°F (8°C), touch 1 and 5.
  5. When you have made the adjustment, touch the START pad to go back to the time of day display. Use your oven as you would normally.
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not light off: when temperature is set & start button pushed,(Bake mode), gas does not come in and no flame is present. In broil mode, the same thing occurs---no gas, no flame.
sounds like a bad ignitor(s) you pres start and temp never goes above 100, looks like it should be workin just never heats??? if so that s the most commmon problem
Oct 09, 2010 | GE Profile Spectra JGBP85 Gas Kitchen...
GE Profile Gas Range, oven doesn't heat up on any
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list above.
Jan 28, 2010 | GE Profile JGS968 Gas Kitchen Range
GE Spectra XL 44 gas kitchen range. Oven does not work
Sounds like the switch module is defective.  You might get lucky if you power down the stove for half an hour and then reapply power.   Sometimes they reset.  If you, enjoy.  If not, you will need that module.
Nov 09, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Thanks
Mar 14, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Profile JGSP48 Gas Kitchen Range Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
