Question about Hitachi 46F510 46" Projection HDTV
Display is bigger than screen
When i play on my xbox 360 or watch digital cable, the display on the screen is slightly cut off on the sides and bottom. Is there a way to adjust the display so that it fits on the screen?
I have a panasonic PT50LCX64 tv a blue screen comes on and say,"airfilter need cleaning. I have vacumed, it worked for awhile only to do the same thing again
Posted on Jan 05, 2009
When I play a gane the sides of the screen cut off
If you have a widescreen TV, your resolution is likely the cause of this. See if your TV has a resolution setting in its menu. Don't worry if it doesn't, some TV's only have one default resolution.
Check what type of cable you are using to connect to the TV. If you are using composite cables (red, white, and yellow) and you have a flatscreen/HDTV, you should switch to component or HDMI cables. (Your Xbox may have came with component cables. They are the red, green, and blue ones, if it did and you aren't using them, use them.)
Once you're using component or HDMI, the problem should be solved. If it is not, change the resolution on the Xbox. To do this, go to System Settings > Console Settings > Display and mess around with the settings in that to find out what works for your TV.
Apr 20, 2011 | Microsoft Xbox 360 Console
Xbox 360: colour/display failure
most likley a cable issue if you are using hdmi make sure its fully homed in same with the others but have you checked the display settings on your xbox? otherwise borrow another cable just to find out
Aug 06, 2009 | Microsoft Xbox 360 Console
Xbox 360 makes televison screen fuzzy and difficlt to see
Firstly check the system configuration blade on your Xbox 360 startup screen and check your display settings, if you've got an Xbox Elite/New Premium and have HDMI cable then it should be set as Intermediate/1080i/p settings, if you have the component cables then it should all be set as default.
If that isn't the problem and your games are still loading up with a fuzzy screen then there is either something wrong with the cables in your Xbox or your TV can't handle the graphics that the Xbox is producing and you will have to go into display settings and try setting them as either lower settings or higher settings depending on the TV you have.
It will help if you can provide details to me on your TV too, I'm not as good with TV's as I am Videogame Consoles/PC's but it will help me if I want to solve your queries further.
Jul 21, 2009 | Microsoft Xbox 360 Console
Plasma screen
do you have the swich on the back of the xbox plug set up for reg tv? Does it work in that mode with just the red, yellow and white wire in the side AV slot? If you were using the xbox on another tv its possible you modified the display settings in the menu. Try hooking it up to a standard tv and reset the setting to default then try rehooking it up to the plazma.
Joe
May 20, 2009 | LG 42PC1D 42 in. Plasma Television
White pixels all over screen when playing game only
Many have tried to diagnose the root cause of thi problem, focusing on the various cables attached to their consoles; but whether using high or standard-definition cables, the same worrying situation of a display blackout occurs.
Others have supposed that the problems are being caused by the hardware component layout within the Xbox 360, blaming its poor orientation as the cause of limited ventilation - and perhaps the subsequent video faults. A few also mention the possibility of an Xbox Live update glitch, which may explain the reason why these people experienced the black screen around the same time.
By best advice is to call Microsoft and see if you are still under warranty and have the system replaced before spending money on new cables.
The number for Microsoft is listed on the back of almost every game booklet.
Oct 17, 2008 | Microsoft Xbox 360 Console
Xbox 360: how to move screen image?
are u using a lcd or a crt television
Sep 29, 2008 | Microsoft Xbox 360 Console
Xbox 360 graphics
Its likely u just have the sockets for ur av cable plugged in incorrectly, this happened to me, the screen was pink though, i fixed it soon enough
Dec 01, 2007 | Microsoft Xbox 360 Console
Non-HD picture issues
Sounds like you may have something generating interference, such as a bad cable shield on maybe a ground connection inside your tv. You might try moving the cables while watching the screen and see if the pattern changes. Double pictures on a screen can be caused by "ghosts", which means that you're getting two signals--- one slightly behind the other. Anything oscillating generating a radio frequency may radiate into your circuits causing this strange problem. Stargazer
Feb 21, 2007 | Sony KP-53HS10 TV
Hitachi 46F510 46" Projection HDTV Logo
136 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
