Question about Refrigerators
How to remove wire basket in bottom freezer drawer
SOURCE: removing freezer drawer
my son fixed it - thx. problem solved
Posted on Nov 24, 2008
lenwest
  • 150 Answers
SOURCE: Removed bottom freezer drawer while moving & can't get back in
Try picking up the drawer and tilt it up as your putting it in,push it far enough and the wheels or what have you will drop in.Or try the opposite.
Len
Posted on Feb 19, 2009
SOURCE: bottom drawer guides stick
Check guides for icing, is it door seal is good? Any frozen moisture on freezer walls and other parts? If door seal bad - replace it.
Posted on May 14, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Cleaning the base of a GE Profile with a bottom freezer drawer.
Click Here=> PDS22MHR and go to page 11 in the PDF. I believe that will answer your questions of removal. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Mar 19, 2010
SOURCE: Is there a way to remove the drawer in the bottom freezer?
Pull the drawer all the way out until it stops. Then lift the front of the freezer drawer (a couple of inches), and pull out further (4-6"). The front will then lower to the floor. Lift the back of the drawer upward and slid the entire drawer forward. You may want to protect your floor. I did the above with the freezer drawer full and scratched my floor a little...
Posted on Jul 08, 2010
How do I move a three-door refrigerator?
open the freezer all the way. remove all the baskets and there should be tabs you push in at the plastic glide covers in back that you have to press in. then the drawer comes out with the glides and rails
May 05, 2015 | Refrigerators
Bottom basket
Flo,
The manual does not say specifically if the basket can be removed or not, but the basket is on rollers. If you can pull the drawer out and tilt upwards, the basket may release. Otherwise, the basket may not be designed to be removed.
Jan 17, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
Bottom basket in freezer
Flo Shirley,
I understand that you are having trouble removing the bottom basket in your Frigidaire freezer. To remove the basket, pull out, and lift up. This basket clips in to the actual glides that hold it at the bottom of the basket.
-Best Regards-
The bottom freezer drawer is not closing so the freezer is getting an ice build up
It sounds like you either have a drawer that's off track, or something has fallen behind the drawer, not allowing the drawer to close. Empty the freezer, and pull the drawer all the way out. Look behind the basket of the drawer and see if some thing has fallen behind it. If nothing is behind the drawer, then the drawer must be off track. At this point, you'll need to pull the drawer out to the most extended point. Now push the drawer back in about 3-4 inches an **** it open fairly hard. Not hard enough to move the whole refrigerator. Just enough to put the drawer back on track. Hope this helps. : )
Apr 24, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
How do you remove the sliding freezer drawers?
1 Open drawer to the fully out position.
2 Remove upper and lower baskets.
3 Remove screws one in each rail marked on side of rail.
4 Lift the front of the drawer up to remove the drawer.
5 Set the drawer on a soft surface to prevent scratching the
finish. If you have other questions please ask, Thanks Sea Breeze
Dec 14, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Our Kenmore Elite (new last summer) bottom freezer double top doors, stopped making ice. The wire that seemingly controls the ice maker is hanging down in a way that is causing difficulty opening the...
Well, that wire is likely the cause of your issue, somebody probably bent it, and now it gets caught on the door or a basket or a food item or what have you, and since it cannot move, the ice maker will not make ice.
Aug 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Im thinking of buying the MFF225VE bottom freezer but am wondering can you remove the freezer baskets to clean the bottom floor of freezer?
The baskets do come out, there are some tabs that can be depressed on each side and the bins come up. If you want to take the entire drawer out you would need to remove a couple of screws from each side to accomplish this.
Let me know if this was helpful or if you have questions.
Thanks
Jun 14, 2010 | Maytag MFF2258VE Top Freezer Side by Side...
Bottom drawer guides stick
Apr 13, 2009 | Sub-Zero Bottom Freezer Refrigerator
Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Feb 21, 2009 | LG LRFD25850 French Door Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
