Question about Dryers
I have a Whirlpool electric dryer, model #LER5636EQ3. Several years ago, we replaced a part due ti the dryer not heating. It worked great, well a few years ago, the dryer began taking 2 cycles to get the clothes dry. Now, it does not heat at all. It still tumbles though. What is the part that is most likely the problem this time? How do we check the "timer"? Where can we find parts locally, we live near Muskogee, OK. Is it better to fix or replace?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 23 Answers
Posted on Jun 23, 2017
2 Suggested Answers
  • 254 Answers
SOURCE: my gas dryer has no heat
long dry times are a venting problem. if no heat at all it could be your ignitor, a thermal fuse, or the secondary gas coils, all are replaceable and reasanoblyy cheap between 30-90 dollars usually so its up to u it u want to repair it.. if long dry times i would unplug the venting from the rear and dry a load if it heats faster than u know ur venting is clogged and u might wanna clean ur ducting and replace that venting tube. also u can go outside while running and see or feel if air is being pushed out while its running hope this helps let me know how it goes
Posted on Feb 22, 2010
Whirlpool gas dryer takes longer to dry though it heats up and turns, yet it has a humming/buzzing noise. What could be the problem?
Had the same problem. There was a bit of a kink in the vent duct which caused lint to build up in duct and also inside the dryer itself over years. I replaced the duct and took dryer apart and cleaned out the air passages.It works great now. As for the humming, mine started about 2 1/2 years ago and I still don't know why.
Jun 04, 2012 | Whirlpool Dryers
Whirlpool Dryer Model LER5636EQ3. Runs for several minutes then stop.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Aug 23, 2011 | Avanti D110 Electric Portable Dryer
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
I have Model # LER5636EQ3 dryer it all of a sudden quit working in the middle of a drying cycle. I Checked fuses in house all OK. Checked to see if other cycles worked will not start or make a sound at...
This problem is commonly caused by a blown thermal fuse located on the blower housing. The thermal fuse is wired in series with the motor and the motor activates a centrifugal switch for the heating element when it runs. These setup makes the dryer fail to start and the heating element not to turn on if the thermal fuse is blown. The dryer seems to no work at all. Verify the condition of the thermal fuse by bypassing it and starting the dryer.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom of the dryer cabinet. Remove the rear panel to access the blower housing and so the thermal fuse.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
The thermal fuse and cycling thermostat are part numbers 3392519 and 3387134, respectively.
Dec 30, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
Feb 14, 2010 | Dryers
Whirlpool Dryer LER5636EQ3 will not heat replaced heating element, jumped out all temp and heat fuses.
Betya missed the thermal cutoff. Located half way up heater canister above the t-stat. This is usually the cause.
Feb 13, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
I have a whirlpool dryer LER5636EQ3 that will shut off after 3-5 mins.
Go to and enter LER5636EQ3. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Whirlpool video that shows disassembly and identifies major parts.
May 18, 2017 | Whirlpool Dryers
Whirlpool ler5636eq3
check and see if belt is broke you have to lift the top and then remove the front with two screws on each side on the inside pull out and up. after you lift the top you will see the tub and a belt should be on it if so lift up on the belt it should be snug if it comes off in your hand bingo there is your culprit remove front and install new belt
Dec 27, 2007 | Whirlpool LER5636P Electric Dryer
Dryer runs but with little heat
Generally whilpool dryers heat of dont heat.. output should be around 150 .. i would check hose to make sure not clogged or just run without hose and see if that makes a difference... post if need more help
Oct 29, 2007 | Whirlpool LER4634J Electric Dryer
Dryers Logo
Top Dryers Experts
