Question about Home
Briggs toilet won't stop running - Home
4 Suggested Answers
SOURCE: toilet running and won't stop.....it
When water goes over into overflow tube then that means 2 things.
The rubber flapper at tank bottom is good and does not need replacement at this point.
That leaves 2 possible problems.
1) The flush valve needs to be adjusted so water turns off sooner.
Flush valve lets water into the tank.
For example if you have a float ball on end of brass rod, just bend the brass rod so the float sits lower in the water.
If you have the 'fluidmaster' then a float rides up and down with water level. There is a metal rod with a metal clip. Squeeze the metal clip and move it downward on the metal rod.
2) If water will not turn off after adjusting flush valve, then replace flush valve.
Local hardware store sells the part and can help with instructions.
You need a crescent wrench or large adjustable pliers.
Plumber can also install the flush valve.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plunbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 17, 2011
  • 117 Answers
SOURCE: I recently tried to install a Peerless Toilet
return it sometimes they dont work on everything or has a flaw that you cant see
Posted on Nov 01, 2011
maninblack5
  • 13 Answers
SOURCE: our toilet won't stop running.
the flapper is either stuck open or the fill valve shut off is broken
Posted on Nov 08, 2011
Toto toilet won't flush
Replace the assembly. This is common in areas with high mineral content in water. You will be glad you did. Delay too long, you may find your toilet running while you are at work .
Jan 25, 2013 | Toto Drake ADA Compliant Toilet with...
Crafsman 2400 watt generator star ok but only run for 45 sec.& it won't star again the motor is a briggs & stratton 5.0hp
I have a Craftsman Snow Blower with a Briggs & Stratton Engine. I had the same problem. I searched online and read a little bit about this run and stop problem. One solution was to put something over a piece of metal that separates the hot engine part from the other part of the other side of the engine. I used a piece of heat resistant cloth from Lowes in the plumping area where the torches are. It fit and worked. Engine keeps running. I ran it for over an hour last spring prior to storing it.
Nov 01, 2012 | Electrical Supplies
Water won't stop running in glacier bay n2316 toilet
Replacement parts you can find on amazon. take a look here Amazon com glacier bay toilet parts Hope this was helpful. cheers
Jul 03, 2012 | Home
My toilet keeps running and won't turn off
try re placing flapper valve located at forward center of tank.
Feb 26, 2012 | Home
My toilet won't stop filling up so goes over the
Adjust or replace the float. Odds are its stuck. make sure it moves freely up and down. If you cant see the float "normally located on the left side of tank " adjust screw or nob at the top of tube on left. If you still have trouble, replace or adjust flapper valve [located at the inside bottom center of tank] Adjust with chain hanging from flush handle.
Jan 18, 2012 | Plumbing
I recently tried to install a Peerless Toilet Flapper and it won't stop the water from running in the toilet
Nov 01, 2011 | Home
Our toilet won't stop running.
Oct 20, 2011 | Kohler - Toilet - One-piece - San Raphael...
My daughters TOTO toilet kepted running so she turned off the supply line before she went to bed. when she woke up the next moring and turned the water back on, now the tank won't refill. How do I know...
There could be several reasons why it won't refill. It could be the fill valve, which can be replaced with a standard fill valve located at any hardware store. The more likely reason is the stem inside the shut-off of the toilet has broken off inside the valve. This is very common when a valve is older and usually doesn't get shutoff. If this is the case, a new shut-off valve must be soldered on.
Aug 29, 2011 | Toto CST743S Drake Round Toilet
Home Logo
195 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
