Question about Yamaha P95 Digital Piano
P95 Yamaha key broke - Yamaha P95 Digital Piano
3 Suggested Answers
  • 5603 Answers
SOURCE: My yamaha p95 needs to
You have set the transpose to +1. You need to reset the transpose function to zero or no transpose.
Read here: http://faq.yamaha.com/us/en/article/musical-instruments/keyboards/digitalpianos/p_series/p-95_color_variation/4713/3479
Posted on Apr 08, 2011
  • 43 Answers
SOURCE: key doesn't work properlyon yamaha p95 piano
take it back, its still under warranty. That means the key has a contact problem in the circuit. you have to take it all apart, clean it, check the contacts....probably lint. You can try vaccumming it and it might fix the problem. I bought one too and it wasnt good
Posted on May 07, 2012
Manual for Yamaha P 160 Need a Manual
For the P95 user manual visit
https://uk.yamaha.com/en/support/manuals/index.html
However there is no P160 should this read PSR160 in which case select this at the same link.
Dan
Apr 30, 2017 | Yamaha P95 Digital Piano
Fixing noisy keys. Can I do it? Or what should I do?
you cannot fix noisy keys...that's how your model is meant to sound
Nov 23, 2015 | Yamaha P-95 P95 DIGITAL PIANO BLACK
How do i fix a Yamaha P95 that sounds Es with Fs and Bb with Bs across all the octaves?
Whether it happens to all of the key?
If yes, transpose setting may have changed. Change the setting to normal (0).
If the normal transpose, but tuning is still not standardized, check Pitch Setting.
To Restore Standard Pitch setting:
Hold down the A-1, B-1, C0 and C # 0 keys simultaneously and press any key between C3 and B3.
View image :
fix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-0.jpgfix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-1.jpg
If the above procedure is still no effect, try resetting the factory settings / Initialize overall: :
This is the steps:
Initializing the Settings
When you initialize the settings, all backup data stored to this instrument will be initialized and reset to the factory default settings.
Turn off the power to the instrument. Then, simultaneously hold down the C7 key (right-most key on the keyboard) and turn the power on again.
NOTICE
Do not turn off the power to this instrument while it is initializing the data in its internal memory (that is, while the button indicators are flashing).
View image:
Notes:
If this instrument somehow becomes disabled or malfunctions, turn off the power to the instrument, then perform the initialization procedure.
Sep 07, 2015 | Yamaha Music
My yamaha p 95 .Only touch key (D-G-A)on Same time, will be more G # key Sound? What is the problem?
I have this problem too and it got worsened over time. Have you found a solution yet ?
Apr 01, 2015 | Yamaha P95 Digital Piano
P95 making noise when pressing any key or any sound. (piano,organ,etc.)
thats a motherbord problem./ ic called tone generator which is usually faulty.
Sep 24, 2014 | Yamaha P95 Digital Piano
Why power cutting out on yamaha-p95
Hi, This could be for a number of reasons the most common causes are :
1) Socket where mains adaptor is plugged in becomes loose on the PCB and will need to be replaced / repaired
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=17018
2) The power supply unit fails and needs to be replaced. You should only use the correct power supply for your instrument.
Jun 24, 2014 | Yamaha P-95 P95 DIGITAL PIANO BLACK
Key doesn't work properlyon yamaha p95 piano
May 07, 2012 | Yamaha P-95 P95 DIGITAL PIANO BLACK
Spilled water on keys. the d keys all seem louder than the rest and out of tune
You need to dry the water off before it corrodes any electrical connections, disconnect the power. Put the keyboard somewhere warm or it would be best to dismantle it and dry the water with a cloth.
Feb 23, 2011 | Yamaha P95 Digital Piano
The Yamaha P95 is have a semitone out. Using the transposing function moves it up or down a semitone, however it's still out from concert pitch where it should be?
how come mine is ok, maybe it's depends on where you bought it.
<a href="http://bestdigitalpianoreview.com/yamaha-p-85-review">Yamaha P85 Review</a>
Feb 12, 2011 | Yamaha P95 Digital Piano
Yamaha P95 Digital Piano Logo
41 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
