Question about Garden
Oil capicity Model: 917.378960 or 917378960 Craftsman Rotary Lawn Mower 5.5 HP Power Propelled 21 in. Multi-Cut
  • 205 Answers
SOURCE: How do I change the oil in a Sears Craftsman MRS
Tip the mower up on it's side with the dip stick tube on the lower side and dump the oil out. Best to run the mower till its out of gas first.
Posted on Apr 24, 2009
  • 133 Answers
SOURCE: Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Posted on Aug 16, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
  • 16 Answers
SOURCE: lawn mower died while mowing and won't restart
check the carb and air filter... also make sure its not gas from last season and make sure the oil is good.
Posted on Aug 20, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
What type of oil filter do I need for a lawn tractor 24H.P. 46" mower Model #28857
Any good 30 SAE weight is recommended for grass mowers..if used with a snow blower use a good multi viscosity 10-30 or 5-30 ould be fine..good luck..
Jun 27, 2015 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
MY CRAFTSMAN 6.75 HORSEPOWER 21" MULTI-CUT POWER PROPELLED ROTARY LAWN MOWER MODEL NO. 917.377972 WILL NOT START AND RUN . STARTS THEN QUITS HAVE TRIED EVERYTHING IT HAS BEEN A SHOP LAST TWO YEARS HE CAN...
If the carb is new, then make sure the fuel is fresh- LESS THAN 30 DAYS OLD!!! Is the plug good? Air filter OK? Good oil in the engine? Make sure that the shut off cable hasn't stretched. It may make contact and shut off the engine.
May 20, 2014 | Mtd 22" Yard Machine Push Mower
How do I install part no.183281 ( engine zone control cable ) onto a craftsman rotary lawn mower model no. 944.366362 ?
Hi Robert,
I'm not usually a Lawn Mower Expert, but I think I may have an answer for you. Assuming your craftsman rotary lawn mower is similar to this self propelled craftsman mower (they should have the same basic parts), this video should help!
Self-Propelled Craftsman Lawnmower Drive Cable Repair
Sep 05, 2013 | Garden
Chugging motor, lots of white smoke.
oil has either run into the muffler or the air filter assembly clean out and good to go.
May 22, 2013 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Garden Logo
154 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
