Question about RCA F32450 32" TV
F20530WN 08/1991 When the TV is turned on it soon starts powering off, then on, and will continue doing so until the user turns it off. I have an old JVC 35" TV (mid-1990's) that did the same thing. I was able to replace a capacitor on the circuit board, and it has been working for over a year now. Could the RCA have a similar solution?
Well, we have a FPR725ER RCA ColorTrak tv from 1987 and we had the same problem in 1997 I believe... It cost over 100 dollars to fix but it was worth it. (not positive what was wrong with it, I suggest you just talk to a tv repair shop. RCA'S of that era are WORTH spending money to repair, those RCA's will last a lifetime if your willing to spend a tiny bit) (coinicidence - I have that same tv your talking about too! the F20F30WN)
Posted on Aug 29, 2007
My tv, when plugged in just keeps turning itself on and off in intervals of about 3 seconds. It doesn't give time for anything to come up on the screen at all.
Problem is in standby power supply or microprocessor area---not the do it yourself repair and likely not economical to repair due to age and brand of set.
Sep 01, 2012 | Philips 60PP9352 60" Rear Projection...
LG 42pc5d plasma television. As soon as you turn it on, it turns back off immediately. Started off with problem of turning it on and had sound but no pic. Once you turned it off and back on again, it...
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will help in solving the problem.......
Jul 08, 2011 | LG 42PC5D Television
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
Acer aspire one stuck in safe mode
Turn the computer off. Hit the power button to turn it back on and as soon as you do start tapping the f8 button continuously until you get a list of options. Select the option "start windows normally"
Jan 14, 2010 | Acer Aspire One PC Notebook
Magnavox MODEL # HD1905 C121 CHASSIS # 19E604-00AA SERIAL # 43468127 My Magnavox is stuck in a demo mode. I cannot turn the power on or off, and NONE of the buttons work, nor does the...
on the set press and hold the up and down volume buttons together till the tv turns off then press power to turn back on and everything should be fine
Jun 10, 2009 | Philips Magnavox 20MS3442 20" TV
Cannnot control my new emerson tv using my COMCAST controler. model LC320em9 what code do i need to use to make this work.
you need to hit the tv button, then hold down the setup untill the lights plink twice, then hit 991, then power, if it doesnt turn off, hit tv again, then the power again, keep doing that untill the tv turns off, as soon at it turns off, you need to hit the set up button again, that locks in the code, then you should be able to turn it back on with the remote
Jan 08, 2009 | Televison & Video
My Sanyo TV, 3 year old turns off with a click sound, as soon as it is turned On
Hi
your tv has defective power oscillation! the click sound that is relay power source. if the relay is click back you have defective small parts in power section! do you have experience in electronics?
Thanks!
Jun 22, 2008 | Televison & Video
Sporadic Hum on HLP4663W
I would guess that its the fan for the lamp, as the color wheel will power down as soon as the power is cut. the cooling fans will continue to run
Jun 12, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Receiver continously turns on and off
In this case, it is an important issue that what type of connection you've had between the amp and the TV (scart, s-video, rca, etc.) It seems to me that yours is an impedance issue. Refer to the user manual of the amp and check out the allowed or recommended impedance values, then buy appropriate interconnections.
Aug 05, 2007 | Yamaha HTR-5630 Receiver
RCA F32450 32" TV Logo
101 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
