Question about Marantz SR7002 6.1 Channels Receiver
When running video thru the amp, the pic flashes on and off
I switched hdmi cables and the problem persisted. When I ran component cables from the DVD player directly to the TV the pic was fine. Thinking the flaw might be in just the Marantz DVD hdmi input, I tried the VCR input with the same results - picture sporadically flashes on and off while the audio is uninterrupted. HELP! and Thanks.
  • Anonymous Apr 15, 2009
    lost the hdmi through the receiver as well. works fine while bypassing
  • 3 Answers
Usually that is an issue of cabling and/or the monitor. The Marantz units are pretty darn stable. Check your setup to see if it is upconverting.
If you can, try a new HDMI cable to the TV. You could also try the second HDMI out, to see if there might be a problem with that particular output port. You can also try a different HDMI port on the TV.
Another thing to try is to directly connect your DVD player to the TV. If your cabling is all in walls, etc, you can get an HDMI coupler at a big box store for $15.00 or so. That will tell you if it is any of the cables, the DVD player, or the TV.
Posted on Jan 18, 2010
I just bought a yamaha rx-v365 receiver and hooked to my cable box via a hdmi and optic audio cable. this is working fine but i cant get a dvd player to work via a component and coax audio cable. neither...
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
Nov 25, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
Audio doesnt come thru my hdmi cable from the dvd player. And video doesnt go thru hdmi cable to projector. Have to run rca cables to both
Hi there
Check your DVD players' settings/manual to ensure the HDMI port is the default output port. Also confirm that both audio and video are enabled on that HDMI channel as it can be separated to be only video or only audio in a lot of cases.
Confirm you are at least getting video out from the DVD with a direct connection to your projector with the HDMI cable.
If video is making it to the projector direct from the DVD, you will need to confirm your amp is monitoring the HDMI input if there isn't a specific input selection for it. Connect your DVD to the amp and your amp to the projector and test again that you are still getting video AT LEAST. This will help narrow down which device is not playing the HDMI game if you still have issues at this point.
To sum up;
Confirm HDMI is the default output from the DVD for both audio and video.
Ensure you are getting video AT LEAST with a direct test to projector.
Confirm your amp is monitoring the HDMI input coming from the DVD.
Hope this helps.
Jul 29, 2009 | Yamaha HTR-6130 Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Jul 09, 2008 | Denon AVR-3805 Receiver
Xbox 360
There are a couple of options you can use.
Are your DVD and cable actually going to the Onkyo first and then to the TV? I am assuming it is, if you listen to the Onkyo when watching a DVD or cable.
The Onkyo receiver you have has 2 hdmi inputs and 1 hdmi output.
Does your Xbox360 have an hdmi output and that is what you want to connect to the Onkyo? Some do and some don't.
If your Xbox has a hdmi output and you are already using the 2 hdmi inputs on the Onkyo, you can not connect the Xbox using the hdmi, you have no more hdmi to connect to, so you must go thru one of the other inputs of the Onkyo.
The hdmi has the video and audio together, the other video options do not. you would need to run seperate audio cables as well.
Your Xbox should have a composite video (yellow RCA jack) output or a component video (1 red, 1 blue, 1 green RCA jack) output.
When you connect the Xbox thru, lets say the composite video of the Onkyo , you will also need to connect the audio from the Xbox to the Onkyo on the same input. It should be right next to the yellow RCA jack or right under it. They are 2 RCA jacks, one red and one white.
You will then need to connect the composite output of the Onkyo to the composite input of the TV.
When connecting like this, you will also need to select the composite input on your TV with your remote for your TV. Your TV should have an input button that lets you go thru all the different inputs to it.
you can also use the component video from the Xbox if it has that. But you must also run the audio to the Onkyo as well to the corresponding audio inputs of the component video input on the Onkyo.
This may sound a little confusing, but remember that the hdmi has the audio and video in one cable, the other video options do not, so you must run additional cables for the audio to the Onkyo from the Xbox.
Also remember whichever video you use from the Xbox to the Onkyo, you must also run that same video from the Onkyo to the TV and then switch the TV over to that input when you want to watch the Xbox on the TV
Jun 21, 2008 | Onkyo TX-SR605 Receiver
Video Monitor Out issues
Just to be clear, what is the input you are using on the projector?
Thanks,
Dan
Apr 18, 2008 | Denon AVR-3805 Receiver
Sound, but no picture
The hdmi inputs on this unit go directly thru the main digital pcb. and the component inputs feed thru the av pcb then to the main pcb. If the composit hook up do not work and hdmi inputs do work the unit has a bad AV pcb.
Nov 08, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Marantz SR7002 6.1 Channels Receiver Logo
357 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
