Question about HP PSC 1210 All-In-One InkJet Printer
Out of paper, but really note
My printer won't print anymore. It says printer out of paper, but I have paper in it. I hear it wanting to be fed by the paper, but nothing is working. I restarted it, took paper out, put more in, checked the back, nothing works.
I have the same problem....I look for and you have to change the part inside the printer that pull in the paper..I was having the same problem and it works...any question my email is
Posted on Jan 06, 2009
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
My HP officejet Pro L7680 cannot scan anymore. It keeps saying: "Reload the Document & restart the job. And when scaning through PC then give an error msg: "The automatic Document deeder is...
does the feeder try to fed the paper? if you hear not working and not fed the paper then clean with alcohol with hard paper the roller .
if not fix did you hear noises? maybe the gears.
hope i help
Dec 02, 2010 | HP Officejet Pro L7680 All-In-One Printer
When I try to print, the printer sounds like it wants to print but the paper does not get fed into the machine it just makes a really weird sound.
hi.... First check the lifter *** lifting the tray, when the caridge block move towards the left it pushes the plastic lock of lifter assembly to lift the tray check them for working if it works then go to next step..
clean the feed roolers & replace the paper seprator of the printor satuated on the end of paper feed tray (brown colour).
Your problem will be resolved 100%.
Aug 31, 2010 | HP DeskJet 612c InkJet Printer
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Won't photocopy / warning light flashing /
The paper feed system is worn (rollers, and separation pad). What is happening, is extra sheets are being fed into the machine primarily because the separation unit is not doing it's job properly. So rather than just one page at a time being fed, it is allowing an extra sheet to "creep" in intermittently, causing the jam. And the indicator you are seeing is the "jam" indicator.
Jul 16, 2009 | Canon PC170 Copier
I can't seem to control which tray the paper is fed from.
My idea is that you have the wrong printer for the job. Yes. It will automatically take anything that is put into the upper feed section, because it is actually the same feed section- it uses the exact same feed rollers to feed from the bypass tray as the main tray, this is designed only as a convenience for the occasion you want to print different size paper you may want to run, or for re-feeding for duplex
Mar 21, 2009 | HP LASERJET P1006 Printer
Can't seem to control which tray paper is fed from on my P1006
for windows: go to control panel - printers and faxes - in the printer configuration you need to set that letters are loaded in the main tray
Mar 21, 2009 | HP LaserJet 1022 Printer
Dell 924 All-In-One printer
Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
• Letter*
• Legal
• B5
• A4
• A5
• 3x6
• 4x6
• L
• 2L
• 5x7
• Hagaki
• 10x15 cm
• 13x18 cm
25 greeting cards,
index cards,
postcards, or photo
• The print side of the cards faces up.
• The cards are centered on the paper support, in between the left and right
paper guides.
• The paper guide rests against the left edge of the cards.
• You select Normal or Photo print quality.
25 sheets of photo
or glossy paper
• The glossy side of the paper faces up.
• The paper is centered on the paper support, in between the left and right
paper guides.
• The paper is loaded vertically against the right side of the paper support.
10 iron-on transfers • You follow the loading instructions on the packaging.
• The blank side of the transfer faces up.
• The transfer is centered on the paper support, in between the left and right
paper guides.
NOTE: For best results, iron-on transfers should be fed one sheet at a time.
50 transparencies • The rough side of the transparencies faces up.
• The transparencies are centered on the paper support, in between the left and
right paper guides.
NOTE: You can load a single transparency into the paper support without
removing plain paper.
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Red light on Printer doesn't want to print anymore
pull out the cartridge and look for paper inside, re-install cartridge, also look on the back part where the fuser and exit assembly is look for paper jammed. also make sure the paper is set correctly on the tray.
Jan 06, 2008 | Brother HL 1430 Laser Printer
HP PSC 1210 All-In-One InkJet Printer Logo
Ben Johnson
