Do I need a converter box?
We do not have cable or satellite, but get decent reception with a booster and roof antennae. We just replaced our old television with a Sanyo model # DP26648. No rabbit ears, but a booster and roof antennae. Will we need a converter box after the conversion next month?
Thanks!
Kathy Cohen
  • 124 Answers
Yes you will need a conveter box the switch isnt until febuary 14 so until then you can keep the antena but it may be cheaper for you to just buy satellite if you are thinking about switching in future months when things start to convert to everything in hd but that could be months or years away
Posted on Jan 05, 2009
I have an rca atsc converter box, lost instuctions printed out on line. but need the tv code for my new Sanyo hdtv lcd tv model# DP32640. Can you help? I live in a heavily treed area and think the...
you don't need converter.
get a digital antenna from Walmart along with the power booster that the coax cable screws onto, then a short coax
to the tv. I get great tv from 80 miles away into my woods
Jul 31, 2017 | RCA ATSC11 DTV Receiver
I am getting a NO SIGNAL as soon as I turn on the TV
Antenna may have to be re-aimed or replaced. Go to www.dtvanswers,com for details.
Jul 01, 2009 | Insignia IS-LCDTV32 32 in. Television
Is my Hitachi 61uwx10b ultravision hd ready digital tv ready when they switch over to digital vrodacasting or will i need a converter box,
This TV will need a converter box. It was made in the days before the digital tuner was required on big TV sets.
Just remember the converter is only needed if you get off-the-air reception with an antenna for local channels. If you have cable or satellite and get your local channels that way, you don't have to do anything. The change to digital will not affect you.
If you are now using rabbit ears or an old worn-out outside antenna, you might think about upgrading your antenna when you get a converter box. Signal strength is very important with the new digital broadcasting. Too weak a signal means no picture at all or one that freezes up or turns blocky. The antenna that worked for analog may not be adequate for digital.
Jun 06, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
No Signal
Make sure you have a good connection from the antenna to the converter box. Set your TV to channel 3 or 4.
The converter won't improve reception in any way, and it's possible you might need to relocate your antenna or get an exterior antenna hooked up to improve the signal strength.
If you have enough antenna cable, and you're only using rabbit ears, hang them out the window or up on a curtain rod and see if that improves things.
Some people have good luck with the new digital style set-top antennas. I think you'll have best luck, though, with an old roof-top antenna that's set up to feed your converter.
Best of luck to you!
Apr 10, 2009 | Insignia Digital-to-Analog Converter for...
Digital conversion
You are in good shape; the specs state that your model has an ATSC compatible tuner so you can receive either analog or digital.
BTW, if you are receiving via an antenna and have decent UHF reception (chan.s 15-69) you won't have to do anything. If you are on cable or satellite dish, they may charge extra for HD reception and a replacement cable box. Otherwise you'll just continue to have those black bars left and right.
Mar 21, 2009 | Protron PLTV-32 Television
We just converted our analog and get a bad picture
I would think it is wise to try another converter box. That is the only way to know for sure. There is also a possiblity that the reception where you are located is very poor.
Jerry G.
Feb 09, 2009 | Insignia Digital-to-Analog Converter for...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Can not get any chanels through the digital converter please help
make sure its set to antenna than have someone go up and turn while u seek the signal try a channel thats works good but not perfect than go from there. if not u have ur plugs backwords in the tv not the device.
Jan 04, 2009 | Insignia Digital-to-Analog Converter for...
Digital signal conversion
If you have cable TV, satellite TV, or FIOS, the coupon eligible converter boxes aren't needed and aren't useful with those services.
They gov't coupon converter boxes are only good for reception with a regular TV antenna or rabbit ears.
According to the specs on epinions.com, no, this TV does not have a digital tuner. So, if you use a rooftop TV antenna (not satellite dish) or an indoor TV antenna, you WILL need an ATSC to NTSC converter box. You need not wait until next year, however, as most U.S. TV stations are also broadcasting digital (ATSC) now.
Feb 23, 2008 | Sanyo DS27820 27" TV
Televison & Video Logo
Top Televison & Video Experts
