Question about Whirlpool LER4634J Electric Dryer
Which wires are positive and negative on my thermal cut-off and high limit thermastat for a whirlpool heavy duty xtra large capacity dryer model LER5644EQO
5 Suggested Answers
SOURCE: whirlpool dryer won't heat how can I fix?
Hey, I just read an article online titled, Testing for 240 Volts to Your Dryer - Without a Voltmeter, here's the link http://www.davesrepair.com/DIYhelp/DIY240Vtester.htm
I am not sure how you could test anything else though, such as the thermal fuse or thermostat, without the Volt/Ohm Meter. They are about $10 at any big box home store--we just went ahead and bought one.
Posted on May 31, 2009
blueextc3221
  • 15935 Answers
SOURCE: Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Jahn27
  • 1554 Answers
SOURCE: LER4634EQO Whirlpool Heavy Duty Extra Large
The problem is likely in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
The
thermal cut-off (cut-out) and high-limit thermostat are sold as a kit with part number 279816 and costs about $30.
In case the dryer still doesn't heat up with the
thermal cut-off (cut-out) and high-limit thermostat bypassed, bypass the cycling thermostat then replace it if the dryer heats up. Check the heating element for broken coils if the dryer still doesn't heat up with the three components mentioned above bypassed.
Posted on Feb 11, 2011
heatman101
  • 43501 Answers
SOURCE: whirlpool estate electric dryer takes three full
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Sep 20, 2011
Whirlpool heavy duty 5cycle 3 temp dryer won't turn on suddenly stopped..no sound whatsoever..changed heating element and still not on
Check your thermal limiter . It should look like a white bar about a inch long . You can find it on the blower housing
Feb 17, 2013 | Whirlpool Dryers
Whirlpool estate electric dryer takes three full cycles to dry. Not sure if it is the heating element or the thermal fuse? This dryer is a 1/3 HP motor large capacity, heavy duty dryer.
heatman101
Sep 19, 2011 | Whirlpool Dryers
Dryer still runs it just isn't getting warm
The heating element is wired in series with a thermal cut-off and a high-limit thermostat both located on the heater housing.The thermal cut-off blows open when the high-limit thermostat fails to cycle off in order to regulate the heating element temperature. When the thermal cut-off is blown, power to the element is cut-off and the dryer will not heat. Replacing both thermal cut-off and the high-limit thermostat if the former is indeed blown. Click on the links below for the troubleshooting and repair details.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Front Bottom Panel) Running But Not Heating
Jun 18, 2011 | Whirlpool Dryers
My whirlpool leb 6000 pqo will not heat
check heating coils, high limit, temp selector switch.
Apr 05, 2011 | Whirlpool Dryers
Dryer goes on and spins but no heat. I've opened up the back but what now? Is there a specific part that if blown would cut off the heat? Model is a small one - probably cost about $300 - don't know the...
The thermal cut-off at the top of the heater duct/housing blows when the high-limit thermostat below it fails to cycle the heating element on and off properly to regulate the heater temperature. This thermal cut-off along with high-limit thermostat including the cycling thermostat on the blower housing are wired in series with the heating element and power to it is cut when the thermal cut-off blows as a safety feature to prevent fire. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 11, 2011 | Roper REX4634KQ Electric Dryer
I have model REX3514PQ0 that I purchased from Lowe's in 2005. It is a Heavy Duty, Extra Large Capacity, 3 Cycle dryer. The dryer will turn on and will blow but only cold air. A friend suggested I check...
There are three switches :: high heat thermostat, low heat thermostat, and thermal limit switch.
Could the the thermal limit switch is opened because the dryer overheated -- these cannot be reset -- need replacing.
Could also be a faulty heating element. To test these components you'll need an ohmmeter (multi-meter) and will need to remove the back of the dryer.
More info, let me know.
Charlie
Feb 20, 2011 | Roper Dryers
LER4634EQO Whirlpool Heavy Duty Extra Large Capacity 4 cycle 3 temptures My dryer is not heating. I have checked the breaker(s). There is not much lint around the dryer in the back or the vent, what...
The
Feb 10, 2011 | Whirlpool LER4634J Electric Dryer
3.6cu ft.
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
Electric dryer wont start
Just replace the thermal fuse for now. You have gotten good use from this machine. But, this is also may be the beginning of the end. Thermal fuses are not expensive either. These things just go out at no uncertain times.
Feb 01, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer has power but will not start
check the thermal limit on the blower housing if it is open and it has no resistance reading replace the limit, it is a white limit and has 2 blue wires connected to it part number 3399849
May 05, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
44 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
