Question about Logitech X-530 5.1 Speakers
My logitech speakers arent working and everything is surely plugged in right
Its not staticky and the green light goes on but theres no sound coming out and ive been using it for a while with no problem, but now its not
Open SKy
  • 618 Answers
SOURCE: Using headphones with Logitech X-230 speakers
Hi FOG-57
Happy HOlidays!
well, if volume is fixed, you have to see if in the control program for sound, you can disable and use the headphone sound program in windows.
good luck
Posted on Dec 26, 2007
SOURCE: Logitech x-230 - left speaker not working when used with 360
Get your system to a repair shop! Note that the problem is in the PB9 jack at the back of the subwoofer and don't try to wiggle anything yourself - they're great speakers, don't do anything you'll regret.
Posted on Oct 27, 2008
  • 15 Answers
SOURCE: hooking up logitech surround sound to tv.
you need a "y" cable to bridge the output of the tv to the speakers.
Godd Luck
Posted on Jan 25, 2009
SOURCE: Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
Posted on Feb 18, 2009
AldRezaine
  • 995 Answers
SOURCE: My right speaker will not output any sound.
Reconnect all the wirings of the speaker set. Left and Right sound connectors from the subwoofer properly.
Posted on Nov 03, 2009
Testimonial: "Everything is plugged in properly. I've replugged and still nothing, still out. Headphones right piece is out in the remote but not in the comp"
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
My logitech z-640 speakers arent working and i have no clue why first id like to know where to plug in the plugs in my laptop theres a geen,orange,black cord i have a microphone,headphone and some other...
The different connectors are for 5.1 surround audio, and are for different speakers with your system.
  • The green connector is for your front-right/front-left speakers
  • The black connector is for your rear-left and rear-right speakers
  • The orange plug is for your center speaker.
Most laptops do not have support for 5-speaker audio, so if you want to test each individually, you will need to plug them in one at a time and test playing sounds through them.
Hope this helps,
Dec 17, 2010 | Logitech Z-640 Computer Speakers
I HAVE A Z-2300 NO SOUND
Is it plugged in with a 3.5 millimeter jack? If it is, pull it out of the computer and press you thumb on the tip, if no humming noise comes out, your speakers are probably blown.
However, if a humming noise does come out. Please check to make sure the volume on the computer is turned up/unmuted, the software's volume is turned up/unmuted, your sound card driver is installed (Right-Click "My Computer" -> left click on properties -> Click on the Hardware tab -> click on "Device Manager" -> Click the "+" next to "Sound, video and game controllers" and make sure there is no Red "X"'s or yellow "!"'s.
If you do get a hum, and you do have everything set up right in Windows, try a different pair of speakers or head phones. Your sound card might be fried.
Also, make sure you're plugging the speakers into the correct port on the computer (It's usually a washed out green port"
Mar 01, 2010 | Logitech Audio Players & Recorders
My speakers arent working and i dont understand why. It shows the green light, and says that everything is plugged in properly.
Have you altered volume level in the PC to Max??
Are they pluggd into the PC sound card port (Green). If so, go into control panel / Sounds / Sounds / Audio and see if driver is NOT greyed ouy, if it is then driver is either not installed or corrupt.
Simply download the mobo sound driver for it and install,
Alternatively you can go into device manager and delete sound driver / scan for hardware changes.
Dec 23, 2009 | Logitech Audio Players & Recorders
I have acompaq presario 6000 but when I moved and plugged my speakers bak in al I get is static. I cannot get any sound. I plugged the speakers into another computer and they work just fine so the speakers...
Make sure you are plugged into the small green 3.5mm jack. if there is no sound whatsoever, then it is a failed amplifier. if there is staticky sound then you likely have a failed 3.5mm jack. Try plugging the speakers into a headphone port (if available) or disable to on-board sound device, puchase an add-in 3d soundcard and circumvent the issue.
Oct 01, 2009 | Compaq Computers & Internet
When i unplug my rca rt2250 home theater system. the green light comes on on the right side. then goes off. everything works good after that speakers sound good. but once in a while that green light comes...
this is the amp IC and while unplugging and plugging it in again helps reset the IC for a little while , it will eventually completely quit and will need replaced
make sure that none of the speaker wires(bare wires) are touching or look like they might be where they are connected at
also if turning up the volume makes it cut out or sound bad then this will also indicate a bad amp IC
Mar 12, 2009 | RCA RT2250 System
Logitech X-540 Configuration Confusion
Your speaker system is designed for the 5.1 surround. *********** board manual shows you which wire goes to where.
Dec 13, 2008 | Logitech X-540 Computer Speakers
SPEAKER FRONT RIGHT NOT WORKING?
ive got the same problem but with my z5500
wonder what it is?
Mar 16, 2008 | Logitech Z-5300 Computer Speakers
Logitech R-10 speakers
The R10 speakers are analog speaker drivers are not needed, you may need drivers for your sound card-- quick test plug a headset into the green port on the back of your computer. if there is sound coming thru then the sound card is fine and you need to make sure your connection are correct. if no sound, plug the headset into the front ports for headphones. if sound is coming thru there but not in back the sound card needs replacement the port is bad.
Mar 07, 2007 | Logitech R-10 Computer Speakers
Open Questions:
See all Logitech X-530 5.1 Speakers Questions
Logitech X-530 5.1 Speakers Logo
24 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
