Question about Toshiba 36A40 36" TV
Toshiba 36A40 36" TV / Chassis No: TAC 0011
About two months ago, my wife and I started noticing a faint white horizontal line form at the bottom of the screen, then it graduated to the bottom 4" (approx.)showing no picture. Today 05/23/07, when she turned on the set it was showing no picture about 10-inches from the top with a couple white lines through the picture and no picture near the bottom of the screen again. After a few minutes it started to widen and become clear again. Although, while we watch there is always the bottom 4-inches doing some weird things, but almost unnoticeable. We purchased this television in 2000 and really have enjoyed its picture, compared to our friends Sony Flat Screen. We want to save this baby. Is there any way I can rememdy this? I checked www.magicyellow.com for a TV Repair shop around our geographical region and it only came up with one, which may not even exist anymore. I would like to try to open the television up myself and try to repair it. I appreciate all the help I can get. Regards, Karl
  • sunny456 Nov 05, 2007
    i'm having the same problem as (goeser) was my toshiba had starting getting a space at the bottom and then at the top and now. the pitcure is about four inches wide please help me fix the problem
  • Karl Goesele Nov 26, 2013
    I took it to the dump and turned it in to the Hazardous Materials Department.
    Genius:
  • 1,694 Answers
Bad capacitor in vertical circuit + possible vertical output IC
damage.If you can identify part locations and solder.....?
Posted on Oct 24, 2007
Toshiba CZ32V61 no picture
1) you have problem with the Raster
2) the main causes are a) raster b) picture c) sound d) synch
3) since this are not video, the problem is raster. your must
test the voltage from section horizontal out +125vdc+vertical output +80v+all other circuit +12vdc
4) test the power supply for defective. see the diagram attached
Jul 12, 2012 | Toshiba CZ32V61 32" TV
Toshiba television, rear projection, HDTV. - Model #: 50H13 - Serial #: 15703904 - Chassis #: TAC 0360 Blue horizontal arcing line about 1/3 from bottom of screen, a few inches thick. Text...
ok turn the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
Sep 15, 2008 | Televison & Video
Which part causes Faint Horizontal bars on the screen?
CCFL lamps.
For more details type in this site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search or press Enter. It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site name, either at the bottom part of first search page, or at the top of second page.
Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price and more.
Jun 04, 2012 | Toshiba Regza 42ZV650U LCD TV
Toshiba 32a32 chassis tac 245 powers up for 1 secopnd then red power light flashes.
just fixed one with that problem it was the vertical output ic Q301
that was shorted. try wicking it out. it is a LA7833S.
Postings say to be sure to use the Toshiba part
Aug 17, 2008 | Toshiba 32A32 32" TV
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
May 14, 2008 | JVC AV-27230 27" TV
Toshiba 36A50 Horizontal Line
Ok, The vertical Ic is IC301 Ta8427K And Capacitors around IC chroma 2.2 uf 50 volts. You will see small red capacitor ( with C302....4 or 5 ) reference. Replaced others capacitors on vertical section 220 uf 35 V or 100uf 35V. I hope this can help you. Or if do you have any picture chasis, send to me and I will show you where are the problem., Thank you
Dec 12, 2007 | Toshiba 36A50 36" TV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Toshiba 36A40 36" TV Logo
200 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
