Question about Ruud UBHC Air Conditioner
Programmable Thermostat = Much Higher Bill?
We installed a Honeywell programmable thermostat back in November and our december gas bill came in about 40% HIGHER. We have a Ruud Achiever 90 Plus powered by gas.
the temp is programmed to be 72 when we are here and 67 at night and when we are not home. Everything seems to be working ok. Any thoughts?
  • 6 more comments
  • mconn1 Jan 05, 2009
    It was a honeywell, not sure the model but it has the ability to program temp by time and day of the week. I consider myself somewhat handy and am pretty confident it is installed correctly. Labeled and matched all the wires to connectors on the install.
    Everything seems to be working fine... house gets warm in the mornings and evenings then cool during the day and at night.
    it was a honeywell... brand new from Lowes and it appears to be working perfectly. I think the model number is rth6300b.
    rdrennan, thanks... that was one of my thoughts... so I today turned down the temps and will wait and see if it makes a difference in the coming months. My wife believes that the temp should be set the same for night and day and didn't like the programmable idea to begin with... is this unit a heat pump and therefore set at one constant temp?
    dwcool, yes, I still have the paperwork.
    dwcool...
    System type 1, setting 0 (heating and cooling : gas, oil or electric heating with central air). So, it is not set for a heat pump so changeover valve number is not an option unless I change the system type,.
    I believe I had it originally set for a heat pump but it blew out mighty cold air.
    honeywell rth6300b
    current settings
    1 0
    3 0
    5 5
    14 0
    yep, I have the red wire in red and there is a metal jumper from r to rc
    Thanks for the help!
  • dwkcool May 11, 2010
    what kind off t-stat did you install
    Problem Solver:
  • 10 Answers
You say your bill increased by as much as 40%. You must understand, this has been a much colder winter than usual as well. Not to mention, if your unit has not been properly serviced to the proper temprature rise anually you will be wasting gas everytime it operates. On over 90% of installed units they are operating over their designed temperature rise and wasting fuel and money for the end consumer. This is why it is very inportant to have you equipment service twice a year, beginibg of winter for the heater and begining of summer for the AC. But, more inportantly, it must be done PROPERLY...
Call me and I will explain the procedure...
Richard (Rick) Drennan
Global HVAC Distributors
Ruud Field Support Representative / Instructor
rdrennan@globalhvac.com
900 Spreckels Ave
Manteca, Ca. 95336
Office (877)448-7263
Cell (209)456-0513
Posted on Jan 05, 2009
  • 2 more comments
  • RDrennan Jan 05, 2009
    AAAAHHH... A heat Pump... There is a big difference.... as the outdoor temperature drops the efficience of a heat pump decreases dramaticly. If you have a secondary electric heat strip bessure that it is wired into the "W@" terminal of the thermostat. This is another reason it is extreamly critical that the refrigerant charge be correct. If it is undercharged it will not properly heat the occupied space. If it is overcharged it it will cylcle off to soon and will not properly heat the space. In both instances it will cost substancially more to operate. Have your unit serviced. If your unit is a 12 seer or greater inform the technician specificly to charge your unit to 13 degrees SUBCOOLING, (NO MORE). any thing more will cause you problems and cost you money anything less then 10 degrees will cost you money and not properly heat. And clean the condser coil with a mild cleaner like Simple Green to assit the heat transfer...
    Best of luck..
    No a 90 plus achiever is not a Heat Pump... but if you have a T-stat configured for heat Pump its not going to bring the furnace on. It will only bring the AC on... What is the make and model of the Thermostat you have and I will give you the configuration you need for your application...
    RUUD Field Support Representative / Instructor
    900 Spreckels Ave
    Manteca, Ca. 95336
    1 0
    2 n/a
    3 0
    5 5
    14 0
    Jumper between R and RC
    900 Spreckels Ave
    Manteca, Ca. 95336
    Cell (209)456-0513
    Then the configuration is correct so all falls back to proper service and temperature rise adjustment. If the unit is sized properly for the space per load calcs and adjusted per the temp rise and not over or under firing, which in over 90% of equipment they are, you are fine. I would recommend a PROPER temp rise service adjustemnt be done. The may call me if they are unsure on how this is done properly.
    900 Spreckels Ave
    Manteca, Ca. 95336
    Cell (209)456-0513
  • 96 Answers
Do you still have your program sheet
  • 2 more comments
  • dwkcool Jan 05, 2009
    do you still have the program papers for the t-stat install
    when you go through the setup what is the changeover valve number set at and what do you have # 9 Stage 1 compressor set at
    with this being a gas system you might want to have you gas pressure checked at the gas valve in the unit
    sound like settings are ok
Why is my honeywell 8320r1003 short cycling for hot water heat.I have heat set at 65 degress.cycling 2min,3min,the most is 8min.
Hi Bill, after closing your thermostat, is this correct the situation?
And how far is your thermostat from your baseboard heater, if the baseboard is underneath the stat, you should move the stat elsewhere. Hope this help you find the problem.
Jan 03, 2015 | Honeywell TH8320R1003 VisionPRO 8000 w/...
Honeywell manuals
Turn the fan in the ON position to verify you have power to the furnace. If the fan turns on, turn it back to AUTO. Pull the thermostat off the wall to get to the low voltage wiring. If you have a gas furnace, pull the red & white wires off and pinch them together. If the furnace starts, the thermostat is bad. If it doesn't start, then begin looking for flame roll out switches in the furnace burner compartment to manually reset. If the furnace inducer (combustion motor starts, & you get no flame, then it is either an ignition problem, or someone didn't pay their gas bill. :0
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
I tried to insatll my new honeywell programmable. the old t-stat had a white and red wire connected allread. there were 3 other wires unused, G,W,R. I hook up the original R,W wires to the new t-stat and...
The red and white wires go to the R and W terminals on the thermostat. Disconnect what you have now and hook the red wire to the R terminal and the white wire to the W terminal on the new thermostat and see what happens.
Jan 09, 2010 | Honeywell Programmable Thermostat Heater
High Electrical bill - Appears to be heatpump problem.
Sound like there are running on emergency heat which is elrctric.Have the system checked out buy a local heating and cooling company. Have they checked the filter and changed them.
Jan 14, 2009 | Honeywell Electronic Programmable...
Thermostat turns unit one every 5 min
check your filter if it is dirty it will not allow enough air flow and cause the heat limit stat in the unit to trip causing unit to cut off when it resets it will come back on.
Dec 23, 2008 | Honeywell Focus 6300B 5-2 Days...
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Sep 21, 2008 | Honeywell Programmable Thermostat Heater
Installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Ruud UBHC Air Conditioner Logo
350 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
