Question about GE Monogram Side by Side Refrigerator
How to replace the solenoid ice maker ge monogram
Agent Don
  • 310 Answers
SOURCE: ge monogram water line
the water dispenser does not dispense water, although i can hear the motor running, but water is reaching the ice maker.
any tips?
You may have a clogged water line or filter something blocking the flow of the water or you may have to replace the filter or a water line – it may have a defective sending unit / pump and it would be wise to check it out with a regular service tech and to also check your owner’s manual for troubleshooting.
Posted on Apr 14, 2008
SOURCE: ge monogram zd115c automatic icemaker not making ice
Have you checked to assure the long narrow hose that comes from the upper lback left corner is attached both on top and inside the water tray? This drove me nuts for 3 hours.
Dan
Posted on Jul 29, 2008
Sea Breeze
  • 4654 Answers
SOURCE: GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Apr 27, 2009
  • 13 Answers
SOURCE: GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Posted on May 03, 2009
SOURCE: Ge monogram ice maker makes loud churning noise
Mine has been doing the same thing and foound it was the pump cavitating (dry). What caused it on my unit is there was buildup of minerals on the sides of the freezer plate so the ice slab wouldn't slide all of the way down onto the grid. When the unit would start the next cycle the water would ramp up over the stuck slab and down into the ice bin and then the pump would start making the noise. A related problem could be the cutter grid not heating so the slabs back up and results in the same issue. Look up into the freezer plate next time it makes the noise and see if there is a slab partially stuck.
Posted on Jun 17, 2009
My ge monogram ice maker randomly goes into cleaning mode
Your ice maker is electronic and the electronic board inside has failed. Not much you can do in this case except replace the ice maker. Your Monogram uses a=> WR30X10093 Ice Maker Assembly
and here=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Here is a Ice Maker Service Manual that may help should we have missed something=> HERE
Feb 28, 2013 | GE Monogram ZISS480DRSS Stainless Steel
MY GE MONOGRAM ZIS420D FREZZER IS NOT MAING ANY ICE. WHAT SHOULD I DO
check for continuity on the ice maker water fill solenoid valve in the lower rear area of the refrigerator,then remove cover from front of ice maker, and there are 2 gears inside this cover,follow the instructions on the ice maker by this gear and turn it the way it tells you to,this will initiate a manual ice production,you will see the gears turn by themselves after you help turn these gears initially,then you should see water enter from fill tube in the back of the ice maker if the fill tube isnt froze over,if no ice production occurs the ice maker thermostat could be open(bad) or if it makes ice but doesn't push it out the heater below the maker may be open(bad)
Aug 12, 2012 | GE Monogram ZISS480DRSS Stainless Steel
Bad humming noise for ge monogram ice maker zdis150wss. stopped working entirely.
pretty big job to replace compressor on this refrigerator. Thats video I made on one of my customers monogram. Hope That helps.
Apr 20, 2011 | GE Monogram ZDI15C Automatic Icemaker
GE MONOGRAM ZFS826DRC SS ice maker not working
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Mar 06, 2011 | GE Monogram ZISS480DRSS Stainless Steel
Monogram stand alone Ice machine continually drops ice when full
The thermistor can cause the ice-maker to run at all the time and harvest the ice slab. Replace the thermistor with this part.
Jan 27, 2011 | GE Monogram ZDI15C Automatic Icemaker
Replacement of ice maker solenoid in door
Go behind the ice box and look for the water line going in. The water valve will be connected to the line. Be sure to shut off the water before attempting to do anythang.
Sep 05, 2009 | GE Monogram ZDI15C Automatic Icemaker
Water dispenser has stopped working. Ice maker still works and I've changed the water filter. Still nothing
There are two solenoid valves in the rear of the refrigerator. One that controls water for ice and one that controls water for door dispenser. If the water is not coming through when the button is pushed then have the proper solenoid valve replaced and enjoy. Hope this helps. good luck.
Jul 18, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Check and make sure that the float arm in the ice bin is down and able to swing. This arm should be down until the bin is full of ice which would raise the arm and stop any water flow until ice cubes are removed, and allows the arm to drop again to start the cycle all over again, to replace the ice that was used. The arm has a spot to snap in and be held where it would be in a position all the way raised, to allow the bin to come out for cleaning or all of the ice removal from the bin, such as to dump the ice in a cooler. The arm should be gently pulled down to hang freely and will slowly raise on its own as the bin fills with ice.
Jan 02, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram Side by Side Refrigerator Logo
35 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
