Fridge freezes everything!
I have a Hotpoint side by side model number HSS251FMC, Serial number FD246483
The fridge is freezing everything in it. The freezer is freezing OK but when the heater defrosts it drips everywhere and then freezes the drips, big mess.
Tried all the obvious things like unblocking the drain, rebooting the unit etc etc.
I have tried changing the mother board part number  WR55X10552
and I have also changed the Thermostat DEF part number WR50X10068
The only part not changed yet is the Temp Sensor part number WR55X10025, I have this part so if I need to change it I can.
Any help would be appreciated, thanks, Ric.
  • 15,935 Answers
The defrost timer has failed. It is defrosting too long.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 10, 2010
What temperature should i have my top half fridge of my hotpoint fridge/ freezer as it is too cold and everything is freezing
A good setting is in the middle of the thermostat range. For example, if you have numbers from 1 to 9, 5 would be a good number. If this setting continues to freeze, look for a bad thermostat or temperature thermistor.
Oct 01, 2014 | Refrigerators
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
My is SxS fridge is warm on top & freezing on bottom- both sides
there is a computer board part number WR55X10942 ,if you're in front of the fridge it's on the left hand side down near the bottom,
Mar 21, 2010 | Hotpoint HSS25GFP Side by Side...
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Everything in Fridge side is freezing
your thermostat is probably defective. is an electronic or mechanical thermostat? there is a website called where you can enter your model number and get tech. help along with part #'s., its a very good website
May 08, 2009 | Refrigerators
Hotpoint Fridge freezing the food.
If you give me the model number I can find an exploded view, alternatively enter model number here to get the schematics.
Oct 26, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Everything freezes in the refrigerator
Your damper that controls the air to the fridge side is stuck open. It can be caused by moisture getting on it and freezing it so it wont close or by a failure in the electrical circuit that controls it. There was a service bulletin from about 3-4 years ago about defective control assemblys. I have replaced several and as far as I know Frigidaire is still replacing some of them for free if they fall under the model and serial numbers that were affected.
You can tell if it is frozen by turning the controls off and thawing the damper at the upper left rear of the fridge section with a hair dryer.. After you have it thawed out, turn the controls back on and you should hear the damper door motor running. Keep your thermometer in it and check it after a while and see if it shuts off before it freezes.
Post back with the complete model and serial numbers and I will try to locate the service bulletin at my shop computer tomorrow.
Oct 26, 2007 | Frigidaire FRS26R4C Side by Side...
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
