Question about Sony Bravia KDL-46XBR6 46 in. LCD HDTV
TV Guide not working for KDL-46XBR6, even afer I rescanned for channels
The TV Guide has not work for two weeks now, even after I rescan for channels. I have both the 32 and 46 inch, and this happening on both TV's. The 32 inch states Not Available At This Time. I did not rescan the 32 inch. I did rescan the 46 inch states "searching, check back later, even after TV was off 24 hours.
SOURCE: sony kdl-40s2000
I have had an extremely similar problem with my Comcast Motorola DVR and Sony Bravia with HDMI connection. For months I would lose picture/keep sound when changing from a non-HD to an HD channel. The solution that I found is that there is a setting in the cable box setup that will likely fix your issue. Turn off your cable box leaving the TV on. Quickly press the Menu button on your remote to get into the Box setup. Make sure that 4:3 Override is set to "Off" instead of 480i. I believe this will solve your problem.
Posted on Jan 31, 2007
  • 3 Answers
SOURCE: KDL-26U2000 26 in. LCD Television No picture
sounds like inverter problem
Posted on Nov 10, 2007
  • 39 Answers
SOURCE: Sony Bravia KDL-40v3000
NISK-TRY USING YOUR DIRECTTV MENU AND LOOK AT THE SCREEN FORMAT SETTINGS AND MAKE SURE YOU ARE AT 16X9 SETTING.JOETV
Posted on Jan 02, 2008
SOURCE: Channels three and four arenot
I spoke with your representative in Reading who was very helpful. It mabe a signal strength problem from Hannington that may resolve itself in due course.
Posted on Jul 28, 2008
SOURCE: Sony BRAVIA KDL-40S2000 color problem
you might had problem with the video switcher board. The A board.
Posted on Mar 07, 2009
These answers do not fit my question. One day, on three different sets in my home, where I have received NBC for years just quit working. Did NBC quit broadcasting? It is not snowy, etc, it is just no
Ok This is what I found out and hopefully found your solution..
Have you heard of Double Rescan?
The Federal Communication Comission Designed a Process called double rescan.
Double Rescanning erases and thenreprograms the channels in the converter box an digital TVs memory.
To Double Rescan, you will first need to disconnect the antenna from the converter box or antenna.
Then disconnect the converter and or digital tv power supplies from the wall. Wait a minute before plugging them back in. The antenna should still be disconnected.
With the antenna disconnected run the channel scan function on the coverter box or digital tv. When the scan completes you will have completely removed any channel data the converter box or digital tv, had in its memory.
Now it's time to rescan for real.
Do this by reconnecting the antenna to the converter box or digital tv and running the channel scan function again.
Thus the double rescan is born.
If the double rescan doesn't work, then try some tips and tricks to get your converter box up and running..I will have to look up the url again that has the tips and tricks...
If the double rescan doesn't work let me know and I will look up more options..
I really hope this works..
Dec 18, 2014 | Samsung Televison & Video
Hi there , my YouView tv guide in not working, when pressing the button it access the guide but does not load the channels and it does not scroll . Is there anything i need to do to make it work again
Did you do the retune on Sept 3rd? If not, you need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
The channels carring the EPG may have moved from where the YouView box is expecting them. Try the Factory Rescan
Sep 08, 2014 | Televison & Video
Lost digital channels, only getting analogue installed new antenna, no help other sony lcd is working fine
Got to -
Menu -> settings -> set-up menu -. auto start up
Rescan your tv for all channels.
Any more problems, call sony. 08456000124 local rate number
Dec 12, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
TV works fine on analogue however won't work on digital even when re scanning. When it happened the television froze and then wouldn't work. Now all is has is "no channel available. Please scan" do you...
Power the TV off and uplug from the mains, now remove the aerial, now press the standby button the TV, now plug the mains back in and switch to a DTV channel, wait 5 secs and then put the aerial back in whilst still on that channel, now rescan.
If that didn't work, reset the TV to factory defaults and rescan again.
Thanks
Oct 08, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Lost all digital channels - Sony KDL-52W3100
Use ur original remote of the tv u want setup to the DTV box go menu switch cable back to air
reseption.Set tv channel 3 hook up the DTV box and rescan the channels u have it.
Aug 15, 2009 | Televison & Video
I have a sony kp-57wv600 57 inch tv. and the channel button does not work. The channel button on the tv and the remote does not work. When I hit the channel button all that happens is the tv flickers but...
The first thing to do is to rescan for channels. If for some reason the channel memory got wiped out, there could be no other "available" channels to change to. The "flicker" you see is the TV changing to the same channel. Try the rescan and update this if that does not resolve the problem. Let's eliminate the simple stuff first. If the rescan DOES resolve the problem, please update this with that information as well and we will try to find out what cleared out the channel memory.
Thanks,
Dan
Aug 08, 2009 | Sony KP-57WV600 57" Rear Projection...
Lost manual. How do you make TV rescan for HD
Here's the user guide. I think you might find something that can help you on page 23 of the guide (which consequently is also page 23 of the PDF document).
Apr 16, 2009 | Toshiba 23HLV87 23 in. LCD Television
Philips freeview box DTR 220
Same problem with Channel 71 CBeebies. Tried rescanning which worked initially for a few weeks but it's back and rescanning does not fix the problem now.
Feb 14, 2008 | Televison & Video
Sony Bravia KDL-46XBR6 46 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
