Question about Coleman Powermate Premium Plus 6250W Portable Generator
Motor is locked up and I need to change motors
How do I get the motor and generator separated?
    Problem Solver:
  • 13 Answers
You have too take the accessory cover of the engine to access the bolts that hold the generator to the engine
Posted on Jan 06, 2009
What size generator do I need to run a 10 hp motor
on the plate attached to the motor you will find several important items
one is the wattage of the motor
this is the maximum wattage that the motor uses when under load
the gen set will need to be at least 30% bigger than that figure
next there will the number of phases that the motor is
it will read as 1 ph or 3ph
If it is 1ph that is a single phase motor and will ru from a single phase gen set
however if it is 3ph you will need a 3ph gen set to run the motor
As most single phase motors are limited to around 5hp I would be very sure that the motor is not 3ph
specialist advice from an accredited electrician or electrical motor shop is recommended before buying a gen set. as if you need 3ph the gen sets become expensive.
Aug 07, 2015 | Electrical Supplies
The engine starts but the voltage wont pick up what is the problem
I assume your talking about a generator, check your connections and grounds to the generator motor is self, also some have a switch to separate the motor from the generator as a safety.
Jan 09, 2015 | Electrical Supplies
How to seperate generator from motor coleman 5000 ?
undo the bolts between alternator and motor ,remove motor from frame first.
Aug 10, 2014 | Coleman Electrical Supplies
How do you seperate a kohler motor from generator on a miller welder?
if by asking this im assuming the generator is face bolted to motor , if this is so , to save from having another front bearing , the gen stator is directed attached to motor shaft , on the far end under end bell cover is the end of shaft , a long bolt goes thru gen shaft to screw into motor shaft , MARK/photograph all the wires you unhook helps a lot when puting back together
Aug 05, 2014 | Kohler Replacement Engine Part Pa-64711...
If my generator shut off due to low lubricant will it reset automatically? If not is there a reset valve/button?
The pull cord is like a starter on a car (separate from the motor/engine). If the pull cord will not turn it could be because the motor/engine is seized.
Mar 04, 2013 | BlackMax 3000 Watt Gas Generator - Powered...
Rotor won't turn due to rare earth magnets have to much magnetism. The generator was working fine and the bearings had to be replaced. After replacing bearings and reassembling the generator we were...
You do not say what type/model generator you have, so I will just give you some basics.
There is nothing wrong with the magnets. Their power did not change at all, their pwer never changes, except to degrade slightly over time (hundreds of years.)
The generator rotor is hitting the stator. In other words, the alignment of the rotor inside the generator is off center, making the rotor bind on the inside of the stator, resulting in a lock-up.
With the generator attached to the motor, remove the generator end, and slowly try to turn the engine over by hand. REMOVE THE PLUG WIRE FROM THE PLUG FIRST, so that the engine cannot start. Watch inside the generator, and discover why the generator rotor is not aligned. Pehaps the bearings were installed incorrectly, or the housing is installed incorrectly. Most generator engines have a tapered power-takeoff shaft, where the gen. shaft connects to it. Is this Bolt tightened to specifications? Is there some debris floating around in the gen. (such as a screw, or a pebble, or a nut) that would impede its movement?
good luck
Jun 18, 2011 | Kitchen Ranges
My photocopier is not working and its blinking L 4 signal please advise me what could be the problem?
L4 01 Content Main motor lock
Detail The main motor encoder pulse is
not detected for 400msec.
Cause Main motor defect
Harness disconnection between
the MCU PWB and the main
motor.
Control circuit failure
L4 01 Check and
remedy
Check the main motor operation
with SIM 25-1.
Check the harness and the
connector between the MCU PWB
and the main motor.
10 Content Job separator motor trouble
Details When the home is not detected
within 2.5 sec after the job
separator tray starts to move
upwards.
Cause The job separator upper limit
detection sensor is defective.
The job separator motor is
defective.
The job separator motor periphery
circuit is defective.
The condition of the MCU PWB
JP5 is wrong.
Check and
countermeas
ure
Check the job separator operation
by means of SIM3-2 and 4.
Check the harnesses and
connectors.
Check whether the condition of
the MCU PWB JP5 is correct.
did you oberload with developer?
Dec 01, 2010 | Sharp AR-5316 Advanced Digital Imager...
NAS 2004 Land Rover Discovery Door locking problem.
this is actually the internal DC motor which comes inside the door latch. Land Rover doesn't sell it separately. You need to buy the whole door latch to have this problem sorted out. or else you can buy the DC motor from me as I made a special order from a factory for those DC motors as they are common fault in most of new Land rover generation. each motor costs you $30 +shipping Regards..
Jul 03, 2010 | 2004 Land Rover Discovery
Hayward Max-Flo pump: Need to separate pump from motor
Remove the back cover from the motor, lock the shaft in place, thread off the impeller.
Jun 10, 2009 | Hayward 1.5 Hp Northstar High Performance...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
178 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
