I need to print address labels using the customer list from qiuck book and the dymo 300 label maker
    Scholar:
  • 76 Answers
Hi there, maybe I can help
In my older version of QB I can extract this info in: File/ Mail merge/ and select Customers/ Venders etc. in a sroll down box.
This exports to a .TXT file which then can be used with your Word processing program of your label maker.
Let me know if this helped
Posted on Jan 06, 2009
How do i transport the address book from old computer windows xp to new computer vista
The easiest way would be to identify the location and the file your Dymo printer uses to store its address. Copy the File to a USB memory stick, copy the File on the USB stick to your your new computer, and when you start up your Dymo printing utility open the copied file as your default address library.
The problem you may run into can be caused by different versions of the Dymo printing utility. You may be forced (using the Dymo printing utility) to export the address book on the XP computer and then import the address book on the Vista computer. The picture below outlines this procedure using Dymo printing utility v.8
Also, if you have created any custom label designs you will want to transfer them as well
Jan 17, 2014 | Dymo LabelWriter 310 Printer
How do I import addresses from excel to my Dymo LabelWriter 4XL Thermal Label Printer?
You first need to install DYMO Label. If you already have installed it, click Address Book > Import to import addresses.
^CM
Sep 05, 2013 | Zebra TLP 2844-Z Thermal Label Printer
Paper "30252 address" is not supported
Here is the fix for Win7 provided by Dymo tech support:
1. goto Devices and Printers
2. select Dymo Label Writer
3. On the top where you see Print Server Properties, open it and find "30252 address"
4. delete "30252"
5. delete Dymo Label Writer printer
6. disconnect USB cable and then power to Dymo printer
7. connect power and then USB cable back to Dymo printer
8. reboot PC
9. try printing label again.
Jan 31, 2013 | Dymo LabelWriter Thermal Printer
What is the life expectency for these? Mine doesn't come on even with the AC plugged in
We've had our Dymo 330 Turbo for years and still use it daily to print all our address labels - never had a problem with it. They come with a 3 year warranty, so I guess Dymo thinks they're going to last at least that long.
If the power supply has had it you can get a replacement power adapter but if the machine has had it then time to get a new one I think.
The 300 series was discontinued years ago, and even the 400 series has now been discontinued and replaced by the Labelwriter 450 series.
Oct 24, 2009 | Dymo LabelWriter 330 Thermal Printer
My dymo label writer twin turbo stopped printing on left side!
There are a few common reasons this is problem can exist.
1.) the incorrect template is used when creating the label
2.) the labels are installed incorrectly - the labels must be loaded and pushed against the left side of the printer and lid closed when printing to ensure the labels don't "wander" out of the sensor's view.
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. 4.) the print head is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view.
5.) The labels are defective - if you have another roll of the same size, try it to see if it has the same issue. If not, make sure you purchase quality labels like Dymo name brand or Labelvalue brand Dymo labels.
6.) The printer is defective. Labelwriter 400s have a 2 year warranty, so you can contact Dymo customer support to determine if the printer is defective and return to the retailer you purchased it from.
Oct 08, 2009 | Dymo LabelWriter Thermal Printer
Dymo LabelManager 300
I would suggest reinstalling the driver.
First disconnect the label writer, then go to :
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=101
Scroll down and you will see your model number and download the drivers. Then run the installation again and it should prompt you to connect the label writer, which should fix the problem
If not also try reinstalling the "Label Software Application" listed on the same page as well.
Jul 15, 2009 | Dymo LabelManager 300 Desktop Labelmaker...
This is the error message when openning the Dymo Software on Server 2008. We have openned this same softare successfully on other 2008 Severs. Exception EPrinter in module Labels.DLL at 0000643E6
http://global.dymo.com/enGB/Troubleshooting/LabelWriter_320.html
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      or
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Solution:
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      Solution:
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Solution:
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Solution:
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Jun 16, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
We just purchased a DYMO 400 label printer and I am trying to set it up so that we can print existing labels to it. We have hundreds of word documents formated to print labels on 8.5x11 label sheets. Each...
Your dymo labelwriter came with an add-in for word. just highlight the addresses you want to print, click the little label printer icon in the toolbar and it'll do the rest
Dec 30, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo label 400 turbo.
THERE MUST BE PROBLEM IN THE INK OF THE PRINTER CHANGE THE INK N U WIL NOT FACE IT AGAIN
May 24, 2008 | Dymo LabelWriter 400 Thermal Printer
DYMO DUO LABELWRITER
The labels have a 2 yr warranty, so contact Dymo customer support and if they can't help you return the printer to the retailer you purchased from for a new printer. The Dymo LabelWriter DUO is an expensive printer that Dymo stands behind.
Feb 16, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
