Question about Crock Pots & Slow Cookers
Need a replacement safety valve fot montel williams living well pressure cooker
  • 1739 Answers
SOURCE: I NEED TO REPLACE THE PRESSUR RELEASE VALVE.
Replacement parts for the Wolfgang Puck pressure cookers are difficult to find and I just received an e-mail back from an earlier inquiry to the the company advising that parts are available here:
http://www.wpcookware.com/categories.asp?cat=29
If you do not see the part you require suggest you contact their Customer Service at 1-800-275-8273 or make an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Posted on Apr 01, 2011
  • 1739 Answers
SOURCE: need a steam release valve for my Bristo Wolfgang
Not sure if your model is the BPCR0175 but if the part you require is not available on-line suggest you contact their Customer Service at 1-800-275-8273 or make an inquiry via their webform:
  • 1739 Answers
SOURCE: Looking for place to order replacement Seal Ring
Replacement parts for the Wolfgang Puck pressure cookers are available here:
If you do not see the part you require or are unsure about the model number; suggest you contact their Customer Service at 1-800-275-8273 or via their webform at:
Sorry someone has not responded sonner.
  • 1739 Answers
SOURCE: lost pressure valve for wolfgang puck pressure
Sorry someone has not responded sooner, but just found this site.
  • 1739 Answers
SOURCE: I have lost the pressure valve cap off the top of
Wolfgang Puck Instruction Manuals are available here:
http://www.wpcookware.com/manuals.asp
If you do not see your model number for your product, suggest you contact their Customer service at 1-800-275-8273 to determine if the Instruction Manual for your model is available. Alternatively try making an inquiry via their webform:
Posted on Apr 02, 2011
First time user, steam valve on my xl power pressure cooker sits loosely in the sealed position. Wonder if it is broken. It doesn't turn easily to open. haven't started cooking yet. Can you help me?
the valve is a safety valve to release pressure that gets too high
the action is by the weight of the valve itself sitting over a small opening
as pressure is generated by resistance to flow, that small opening area has to have enough pressure ( psi /surface area) to overcome the resistance to flow ( the weight of the valve body)
when that happens there is a brief loss of pressure and then the valve reseats and the cycle begins again
simple ,effective and safe
to relieve the pressure before opening the lid , remove the valve
Apr 24, 2017 | Crock Pots & Slow Cookers
Is there somewhere I can buy a replacement pressure valve?
Tracy, Check the attached links or try google search your make replacement pressure valve. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Pressure Cooker Parts
Fagor America Shop
May 28, 2016 | Crock Pots & Slow Cookers
I can't take the lid off the pressure cooker, it's as though the locking mechanism doesn't has not disengaged
pressure use a 1/4 turn of the top against the bottom to undo the locks after the pressure in the pot has been released by removing the safety valve
any pressure at all in the pot effectively stops the lid from turning
Aug 08, 2015 | Crock Pots & Slow Cookers
Why is steam and water coming out of the safety valve of the Russel Hobbs preasure cooker
When a pressure cooker is working normally, some steam and a little water is supposed to come out of the valve, that's how you know it's up to pressure.
Aug 29, 2014 | Crock Pots & Slow Cookers
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
Aldi pressure cooker spares
russel hobs or whirlpool?
whirlpool = phillips
russel hobsa = http://www.russellhobbs.com/
Feb 13, 2013 | Crock Pots & Slow Cookers
Displays e4 wont work
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Crock Pots & Slow Cookers Logo
404 people viewed this question
Top Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
