Question about Maytag Refrigerators
How to reset a maytag msd2651heq ice machine
Ice machine stopped making ice. I had the "fix" for it before, but cannot find it now
  • 114 Answers
SOURCE: Maytag Frig. Model MSD2651HEQ not working
Your start relay for the compressor is probably the problem. If ordered, you will most likely receive the relay and overload protector. Replace them both.
Posted on Sep 28, 2007
tbirdfan1
  • 3051 Answers
SOURCE: Maytag MSD24GR ICE MAKER
you need to turn off the water to it then take the arm and move it all the way down and turn on the water and you should hear it click than give it time for the first batch to get made be adviced to throw the first batch away somtimes there is dirt and little uglies in the first batch good luck!!!!
Posted on Aug 09, 2008
  • 31 Answers
SOURCE: maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
Posted on Feb 07, 2009
arikrom
  • 528 Answers
SOURCE: Water leaking in freezer Maytag MSD2651HEQ side by side
you need to open the back of your freezer there is a hole for drain in the bottom...
clean it with hot water and pump so that way you clean the path to the drain pan next to the compressor.
The path might be frozen so use hair dryer at first... good luck let me know if you need more help.
Arik
Posted on Jan 11, 2010
heatman101
  • 43501 Answers
SOURCE: My ice machine stopped making ice, any easy fixes?
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Apr 30, 2010
Maytag refrigerator model MF12665xem7 stopped making ice
If the handle that goes up and down in the ice tray is broken the unit will think that the tray is full and not make ice until you flip the broken handle up to trigger the switch. Check it out.
Sep 28, 2017 | Ice Office Equipment & Supplies
Msd2651heq maytag not working
Compressor is not on. Check out the start relay/capacitor for starting compressor. If latter still does not start and electricity is definitely reaching motor, then compressor is burned out - terminal
Given the age of refrigerator might be better to get a new one since a new compressor and labor to install can be rather high and not cost effective.
Aug 24, 2017 | Maytag Refrigerators
My maytag is model MFD2560HES serial number
does the water dispenser work OK ? if yes , a try this : pour 3/4 of a cup of water into the ice maker, right into where the ejection fingers are. also , take all of the ice out of the ice bin. then , give the freezer time to freeze the water you have poured into the ice maker and see if the ice maker ejects the ice into the bin. if it does, it might reset itself and refill the unit and work normally.
Mar 17, 2010 | Refrigerators
Arik
Jan 11, 2010 | Refrigerators
We have a maytag performa side by side fridge model number psb2151gr the ice maker is not hooked up but it creates ice and collects in the bottom of the freezer and runs out on the floor how do i fix this
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
Water and ice stopped coming out?
MSD2756G if that is the model I need you to confirm. Thanks, Sea Breeze site> http://servicepartstec.blogspot.com/ email appliancepartsse@yahoo.com
Jun 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Sep 27, 2007 | Refrigerators
Ice maker not making ice
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
May 13, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
56 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
