Question about Kenmore 23822 Top Load Washer
Washer will not rinse
Washer will not proceed automatically to rinse cycle and when dial is switch to rinse, There is a low humming sound but no action. If I switch it to spin it will spin.
    Top Expert:
  • Kenmore Master
  • 79,851 Answers
The most common cause of this problem is the washer transmission, there ar lid switch issues but the fact u say it spins ok rules that out, a new transmission is a fairly expensive fix, so if the washer is high hours of use u many consider replacing it.
Posted on Jan 05, 2009
    President:
  • 2,110 Answers
There is a "drain solenoid" which is on the line that allows the water to pump out. It has likely failed. Until it indicates the tub is empty, it will prevent the machine from spinning. If you lift it up and look underneath, you will see this device attached on one side to the drain hose and on the other to the tub. Use a pair of pliers to open the wire clamp on the tub side (all the water will drain out!!!!!), and if (when it is empty) it will spin, the solenoid is bad....if it still will not spin, the controller is bad & you need a new machine!
If it is the solenoid, take it to Sears & they will sell you a new one.
    Genius:
  • 1,269 Answers
The motor is already faulty. Initially you can check short circuit wiring or burned parts inside the circuit of the unit.
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer stops at rinse cycle-hums and has a smell.
Problem is with your lid switch which has to be replaced. This is if your filter is all clean.
Feb 28, 2009 | Kenmore 15864/15862 Top Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Issue with switching to rinse cycle automatically.
Dear G.Arnold,
ngfam at you service
If you are under warranty it's FREE
Sounds like you need service! no cost to you!!!!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Jun 22, 2008 | Frigidaire ATF6000ES Front Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Kenmore 23822 Top Load Washer Logo
50 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
