Question about Coffee Makers & Espresso Machines
Blocked delonghi icona coffee machine
Hi , coffee machine is not heating water, pump working ok, just no hot water!
fest see if you do descaling may halpe to clean the boiler also see ntc which is the thermostat this part is based on the boiler with two leads attached to it this looks after the temperature if not you have to consider the pcb
Mar 26, 2016 | DeLonghi Icona 15-Bar Pump Driven...
Broken water pump espresso
check with the manufacturer's website . they may replace it .
Dec 28, 2015 | DeLonghi Icona 15-Bar Pump Driven...
Why is my new delonghi icona espresso machine steam tube leaking water when I'm not using it, only making espresso.
If it is new, you should return it to the store/manufacturer. The leak should be covered by warranty, however if you attempt any self fix you would void any warranty.
Dec 14, 2014 | DeLonghi Coffee Makers & Espresso Machines
Steam pipe not working
to me the pipe is blocked there is a tool to use to clean this pipe out, hard deposits in the water can block the steam pipe and the tool is a thin bendy wire that you put up the pipe to clean the pipe line out. i would think they sell this pipe in most out lets for coffee makers. check for coffee steam pipe cleaner.
Jun 30, 2017 | DeLonghi Coffee Makers & Espresso Machines
Hi any ideas as to why my Delongi Vintage Icona machine is boiling the water from the water tank?Its contant bubbles from the orange seal in the tank & the water gets very hot sometimes. but it still...
It needs cleaned, sounds like the impurities in the water has plugged it up, white vinegar or coffee pot cleaner. if that doesn't work it will need taken apart and manually cleaned.
Mar 04, 2014 | DeLonghi Coffee Makers & Espresso Machines
Delonghi icona porta filter too tight to turn
Hi mate, had the same problem and fixed it this way. get a tiny drop of olive or almond oil on your finger and run it round edge of the pod in the holder, works a treat
Nov 18, 2012 | Coffee Makers & Espresso Machines
How to descale the delonghi icona pump coffee machine?
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 12, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
We have just opened a De Longhi Icona coffee maker. We followed the instructions to start it, but when we press the coffee button (after the OK light comes on), it makes a loud buzzing noise and no water...
may be you may forgot to fill it up with water...... otherwise i request you to please read the manual book which was given along with machine so that you may get the appropriate solution
Oct 22, 2010 | DeLonghi Vacuums
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
