Question about Kenmore Oasis HE 27082 Top Load Washer
Oasis Washer 110.27082601 Power issue
My washer comes on and beeps randomly with no fault codes. If you push start while the panel is on it turns off. If you hit stop it turns the panel on. If the panel is on and you select any cycle modifiers it turns off. The washer will not start running at any point. One other note, when plugging the washer in there is a blue spark right at the recepticle (possible short?) I also disconnected and reconnected all of the wire bundles under the control panel. Any help deciding if the computer or panel board is bad. Thanks
  • 4 more comments
  • Craig Wood May 24, 2007
    catriver,
    Are you talking the front panel of the washer? Or the front of the control panel? Also, to loift the whole top there are 2 clips near the front to be release with putty knives correct?
    Thanks
  • Anonymous Dec 17, 2007
    Same type of problem only worse. Anywhere in the cycle, it beeps, displat timer flashes, and then shuts off. Then it will come on and go off by itself. If you try to start the cycle again, it does the same. Might be in the same place, might not. I replaced the main control pcb. It worked for the day and started doing the same thing. I am starting to think it is a noisy valve that spikes and causes it to malfunction. Any input is much appreciated.
  • Anonymous Feb 27, 2008
    My washer will not start. It beeps constantly and only one setting can be selected. Most of the time it will not start at all. Unplugging it and plugging it back in does not help. If I walk away and walk over to it again sometimes I can get it to start but most of the time it will just beep.
  • 385590333 Jun 11, 2008
    does anybody have a part # for the keypad or the main computer board,,i have the same problems???
    dr
  • c3res Mar 22, 2009
    My washer mostly will not start. However, prior to the Sears technician coming over it ALWAYS starts and works....weird! Now we are going on the third visit from a technician. Is there a recall on this
  • Anonymous Mar 21, 2014
    Hi , i have an AMICA AWCT10L washer and it has stopped with all but the start panel lights on and no progams can be selected . when the power is turned off and back on , it returns to the same state . Thanks Keith M
    President:
  • 878 Answers
Cj, the spark is normal, just a cap on the board discharging. I had one with the same problem and it turned out to be the touch panel. There is a tech sheet on the inside of the front panel. Pop the top to get it and it should show you how to check the touch panel. Catriver..post back.
Posted on May 24, 2007
  • Ron Marek
    Ron Marek May 25, 2007
    cj, front panel of the washer, left hand side. Push in on the clips and lift the top, should be able to reach the tech sheet...
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Kenmore Oasis no error code keeps beeping low -loud
    If its the main board that you are having an issue with, honestly i will suggest to get a new one instead, might cost you as much as buying a new one if you are going to have it repaired.
    May 14, 2008 | Kenmore Oasis HE 27082 Top Load Washer
    Constant beeping while washing
    This can be due to fault within the control panel output to the indication and buzzer. If the washer works without any issue and the cycles are correct, then it is best to remove the buzzer connections as the drive output transistor or IC could be intermittent and so works erratic.
    Jul 03, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
    F1 code coming up on my Oasis HE washer
    YES! Serious problem...more annoying than anything else. Wait until your machine stops at the spin cycle and displays "F1" again. We just had a repair tech out today and received a quote of $384+ to fix/replace the circuit board. Kenmore & Sears are fully aware of this problem and have issued a recall on a model that is one digit off of the model I have yet they will not do anything about this even though it is the same problem. These machines are huge dogs!
    Jan 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
    My kenmore elite oasis washer will not turn on. I
    its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
    Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
    Kenmore Elite Oasis Washer Beeping Shutting Down
    there are 3 philips head screws in the back of the interface panel.  Loosen them all the way (they don't pull out) and you can rock the interface panel toward the front.  you can disconnect the panel from the rest of the machine by pulling one ribbon cable plug.  the interface card is attached with 3 more screws that come all the way out.  there are two tabs at the bottom that you need to release before rocking the card upward.  the control knob also needs to be pulled out before pulling the card.
    i had the random beeping problem where the wash cycle would be fine (and no codes).  it turned out to be caused by an air wick air freshener that was plugged into the same circuit.  make sure your power line is clean -- remove those pesky interference makers!
    Jan 30, 2009 | Washing Machines
    Kenmore Elite Oasis Model# 110.27087603
    I had a very similar problem with my Oasis He Washer 110.27087603. The machine was randomly cycling through different water temperature indication lights. It would repeatedly beep and not allow a wash cycle to complete. Fixya.com alerted me to the "upgrade" to the electronic control W10112112 to W10189966. My machine was scheduled service and a Sears tech replaced that board. My problem with random cycling continued and the tech stated the touch panel electronics; part # 8564392 would fix the problem. He said one of the microswitches on the panel was probably stuck and not allowing the machine to enter a wash cycle. I found the 8564392 panel at http://www.prosupplyco.com/search.aspx?find=8564392 for a very reasonable price. Realize that Whirlpool parts are Whirlpool parts and Sears doesn't hold the only key to them.
    Oct 29, 2008 | Washing Machines
    Kenmore oasis washer
    This is a common problem with the Oasis. The problem is the User Interface Control board behind the control panel. There's a relay on the board that shorts out and causes the washer to randomly (and constantly) beep. This can also occur with the washer turned off. Since the circuit board is not serviceable it is recommended that you replace the control board. Searspartsdirect.com carries replacement parts for your washer. Just type in the model number and search under the console heading for the user interface board. If you are usure which part, I'm talking about, please post back with your model number and I can assist you. I hope this helps.
    Aug 08, 2008 | Kenmore Oasis HE 27082 Top Load Washer
    Kenmore Oasis HE 27082 Top Load Washer Logo
    252 people viewed this question
    Sal De
    fordexpert
    Whirlpool
    Whirlpool
