Question about Microwave Ovens
I have a Kenmore Microwave BrewNWave 721.63993301 1) My microwave stopped working. The digital information works. But when I press start, all the oven does is click. Is this fixable? 2) I also Want to know how to reset the clock. Please give me directions.
  • 38 Answers
SOURCE: Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
Posted on May 09, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave oven will not work
Seems like I've answered this before, but the MR5493G is subject to a recall due to defective keypad (membrane switch) and can be seriously dangerous.
See: www.allworldauto.com/recalls/samsung_microwave_mr5493g_recalls_1420-10455-1.html
The MR1032BB is also under recall. See: www.motorbeat.com/model/samsung+microwave/mr1032bb/
If neither is covered under the recall, you should be able to order new keypads here: http://www.samsungparts.com/search/search.asp
If not, we'd be happy to help you. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave oven - just stopped stopped working
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave stops after about 2 seconds, also have to reset the clock each time
TO mdambros
You have a bad magnetron. We see this over and over.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You'll save a lot by taking it in yourself.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
TO guest (Panasonic oven)
The door switch you suspected is bad, and it must be replaced. They normally cannot be cleaned or burnished and be reliable.
See http://www.microwavedisplay.com/doorsw.txt
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jul 01, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Eterna Microwave stops after a few seconds, must reset clock..
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, this is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in their bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net
(PLEASE do not be fooled into thinking that the procedure outlined at this link is a "fix". It should only be regarded as another test method to prove that you have a noisy magnetron which must be replaced.)
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
If it keeps failing while the board is in the down position, you either have a very leaky magnetron or possibly another problem.
So you can then get a Ziploc bag and insert a flat piece of aluminum foil into the Ziploc and close it.
Then (with the power off) tape it over the circuit board as best you can, covering it as much as you can, making sure it does not get snagged or punctured.
Then try the oven again. Do not leave this test shield in place as a "fix". It is not safe.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sometimes they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jul 25, 2009
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
I have a kenmore over the counter microwave #721.80032 that is a 2010 model, and the microwave oven just stopped and doesn't work now, but the exhaust part does. Any ideas about what to look for or even...
The door switch is a common problem. Locate it at the front edge of the door. Handle side and try pressing it with a pen or something similar. Start momentarily to see if it works. Do not run for long because of leaking microwaves. That is a good place to start. Here is a link for more help. Kenmore Microwave 721 80032700Troubleshooting Repair Help
May 15, 2014 | Kenmore Microwave Ovens
Kenmore microwave model 721.80039700. microwave starts beeping on its own. Display screen displays 1 then 2 then 3 then 4 over a short period of time. key pad hs stopped working. cannot start of turn...
SOUNDS LIKE A BAD TOUCH PAD THINKING YOUR PRESSING EITHER THE 1-3 PADS, IT WONT TAKE OTHER PROGRAMING CAUSE IT THINKS YOUR PRESSING THE 1-3 PADS. REPLACE TOUCH PAD
Feb 26, 2018 | Microwave Ovens
How to unlock digitals butons?
It sounds like you've activated the child-lock - this would disable all of the digital buttons.
To switch the child-lock OFF, simply press and hold the START button for about 4-5 seconds until "LOCKED" disappears from the display.
To switch the child-lock ON, press "STOP/CLEAR" button once, then press and hold the START button for about 4-5 seconds until "LOCKED" illiminates on the display.
If the buttons aren't working and "LOCKED" is not displayed, then you may have a defective touch control pad.
Hope this helps - please let me know if you need further assistance.
Regards,
BElectric
Feb 15, 2011 | Kenmore 63252 Microwave Oven
Kenmore over the range microwave oven model 721.80413500 keypad just stopped working. No response when pressing any button, even the light and fan button. Microwave was working fine minutes before.
80% of power problems are caused by ceramic fuse locted under microwave cabnet.Use a tester to see if you have continuity.You may just need a fuse.
Jan 29, 2011 | Kenmore Microwave Ovens
Microwave has no power
HELLO I BELEIVE THAT YOU HAVE A BLOWN FUSE, OPEN THE MICROWAVE AND LOOK FOR A WHITE FUSE, NORMALLY IS ABOUT 250V/15A TRY TO GET THE SAME ONE AT RADIO SHACK
GOOD LUCK
CAYPIANAN@YAHOO.COM
Oct 20, 2008 | Kenmore 80809 Microwave Oven
Sylnavia Microwave Oven
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If it still doesn't work, it may be a bad door switch or door switch mount.
One quick check is to gently hold down on the door while you press Start (or Cook).
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
prototech@usa.net
May 16, 2008 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
