Question about Sony VAIO PCG-K27 Notebook
How do I access the inside of my VAIO PCG-K27 notebook to clean i
The computer seems to overheats, van runs noisily and it then closes itself down.
    Sergeant:
  • 367 Answers
This issue will be resolved by replacing the fan in your pc. Go to radio shack or your local computer store for replacement.
Posted on Jan 05, 2009
  • Rob Houg
    Rob Houg Jan 19, 2009
    Couldn't find your exact model number. But try the following manual the results may be similar construction.
Error- "Cannot open AVI"
Download and install VLC media player. Use it to access AVI videos. It pretty much plays all media, and self updating. Did I mention it is free!
Oct 11, 2012 | Sony VAIO PCG-K27 Notebook
How do i log in to my notebook as i have no password
That's nothing serious. I have come across such issue a few days ago, and I tried to reset Windows password in safe mode but failed.Thanks to my friend David who introduced me to use Windows Password Reset , I solved my trouble in a few miniutes.Besides,he also taught me some methods esle as use reset disk, accessible administrator account ect.
In these methods always one could help you.
Mar 06, 2012 | Sony VAIO PCG-K27 Notebook
Need wpa key to connect to network
If this is your home computer, you are probably going to have to reset the router if it is yours
here is a guide
http://support.netgear.com/app/answers/detail/a_id/9665/~/reset-and-restore-the-netgear-device-to-factory-default-settings
Feb 21, 2012 | Sony VAIO PCG-K27 Notebook
Hi, I got a VAIO PCG-K27 Notebook from my friend recently, got problem so need to load window XP os. Now after reloading and reformatting i am having view small ( less 1.5" both sides left and right)...
Use your mouse to RIGHT CLICK on an empty area of your desktop.
Select PROPERTIES.
Select SETTINGS tab.
Move the SCREEN RESOLUTION SLIDER to a different setting.
Click APPLY.
Keep trying different settings until you find one that is acceptable.
Then Click APPLY and OK and then reboot your computer.
That should do it.
Good luck and please rate this with 4 Thumbs Up if it was helpful.
Thank you.
Feb 14, 2011 | Sony VAIO 15.4" Widescreen Notebook PC...
HI WHAT CAN I DO MY SONY LAPTOP K27 IS VERY LAOUD AND RUN HOT
Take some screws out (document where they came from very easily lost) open the case around fan and use a can of compressed air and blow it out.
Nov 02, 2010 | Sony VAIO PCG-K27 Notebook
I need to retrieve data from the hard drive of my Sony VAIO PCG-K27 (the computer won't start anymore- it boots past the VAIO screen, then freezes on a blue screen error message. Also, I no longer have the...
Well take the back cover off the laptop itself and retrieve the hard drive- then simply connect that to another computer and take files from there on to a external hard drive :)
May 07, 2017 | Sony VAIO PCG-K27 Notebook
My sony vaio pcg-k33 shuts off by itself when i turn it on. i think its the video card cause the fan turns on and stays on when i turn the latop on. so maybe its over heating. Please help
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Buy a can of compressed-air, and give your computer a "blow-job", because a layer of dust inside your computer is blocking your heat-radiators, and thus is causing your computer to overheat.
May 07, 2010 | Sony VAIO PCG-K33 Notebook
My sony viao vgn-cs215j suddenly turn off by itself and it takes 20 minutes before i can re-start and use it again and after 15-20 minutes would shut off by itself again without any warning. what could be...
Sorry i nay be a month late on this thread... but better late than never. My Girlfriends sony vaio VGN-CS215J seems to be doing the exact same thing. After buying one of those computer fans that you rest the computer oneverything seems to be running normal. i would also recommend cleaning your fans inside the computer because dirt dust and grime can hold the fans back from cooling down the laptop efficiently and will cause the safety overheat shutdown to activate and shutdown your computer... that way it does catch on fire or fry any of your hardware inside of your computer.
If that does not work... your fans maybe malfunctioning or not functioning at all. this model of vaio has a grinding fan issue that can be very damaging to your cpu if not fixed.
hope this helps,
Mike Huffstutler
Apr 06, 2010 | Sony VAIO VGN-CS215J/W Notebook
Upgrade on Memory Card
When you said memory cards i assume you mean the RAM. You can just take out the ram and put in new ones. Nothing else.
Nov 01, 2009 | Sony VAIO PCG-K27 Notebook
Sony VAIO PCG-K27 Notebook Logo
148 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
