Question about Whirlpool Duet GHW9150P Front Load Washer
Clicking in whirlpool duet
We have a whirlpool duet and it clicks after spinning and the clothes are still wet sometimes it just shuts off. help!!!!!
  • 15,935 Answers
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Whirlpool duet washer not spinning clothes completely
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Washer.
Mar 24, 2017 | Whirlpool Washing Machines
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
This is a rather new unit, this unit is on a direct drive and I would advise that you get techn to look at it, it could be simple solution or quite costly according to what it is, could be several things, go to whirlpool.com and put in your model # and download your document and view the details on your machine, this may help you to decide.
thanks
joyce
Feb 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpoolfront load duet washing machine
"F02" is a Long Drain error. This could be caused by a number of things. The likely suspect is your drain pump. Please click on the following link for instructions on how to diagnose and repair this problem:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
I hope this information helps you. Please post back if you need further advice. Go to my profile and use the "Ask Me" feature for a quicker reply.
Jun 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
165 people viewed this question
Dan Webster
Dan Webster
Sal De
