Question about Amana NAV5805A Top Load Washer
How do you remove the knob off the Timer?
I'm having difficulty removing the Timer knob off the Timer. Is there a trick to it?
  • 883 Answers
Look for a small hole along the side of it that may hold a set screw...turn the screw counterclockwise...the screw may be a hex-head
Posted on May 24, 2007
I finally figured it out - duh! (That was intended for me). The center of the back of the timer has an inner plastic rod that is a different color from that of the timer. Pull that rod out which inturn will release the two tabs that hold's the knob. Once you've done that, you can now pull the knob off the timer.
Posted on Apr 28, 2008
On my Amana LW8303W2, I had to hold the back of the know assembly to prevent the metal post from moving and rotate the knob itself counter clockwise until it came off. This may take longer than expected due to the post rotating which is difficult to detect.
Posted on Nov 04, 2007
SOURCE:
Removing timer knob on maytag washer mav2755aww
It unscrews or if it is a newer model, remove the console so you can tip it forward. You will see a (usually black or white) pin in the center of the timer, pull it out about and inch and then remove the knob from the front by pulling it off the timer shaft. Check you new timer and make sure it comes with one. So did some did not. Good luck.
Mar 28, 2016 | Maytag Washing Machines
I have a Maytag washing machine MAV3905AWW. I would like to replace the timer. How can I remove the knob?
Hello, To remove the knob on this unit you need to push the knob in and on the back side of the timer in the center is a white plastic pin that you have to hold with a small screwdriver while pulling the timer knob off. If you look at the back of the timer while pushing and pulling the knob in and out you will notice the plastic center pin moving in and out.Just hold it out and pull the knob off. Hope this helps.
Jun 06, 2011 | Washing Machines
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
Need directions on replacing the knob-Timer Assembly for the WSXH208V1WW. Bought the replacement part but can't find any instructions for removing and replacing it.
Remove top of washer then Remove timer knob then (2) screws behind knob, un- plug timer connector and replace of course always unplug machine First
Sep 27, 2010 | GE WSXH208A Front Load Washer
The dial to select wash cycle (GE top load washer) seems loose. It is difficult to turn, as if something is not engaging. Any suggestions?
The knob wears out and won't grab. It is easy enough to replace if you know the trick. Take pair of tweezers and remove the clip behind the knob, just push on the replacement knob and oil the timer then move the timer around several times to help the shaft turn easier.b8e8a25.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 02, 2010 | GE WBSR3140DW Top Load Washer
I have a new timer to replace a broken one and I can't get the of
THE TIMER KNOB CAP REMOVES AND THIRS A CLIP UNDER IT REMOVE CLIP KNOB WILL PULL OFF YOUR SEE A SCREW OR 2 REMOVE TIMER MAKE SURE THE WASHER IS UNPLUG FIRST REMOVE BACK PANEL
Apr 03, 2010 | Maytag LAT3600A Top Load Washer
Removal of the timer knob.
you have two different knobs to replace?..is it the water level knob or the timer knob?
if its the timer knob you need to remove, look underneath the timer and you will find a black plastic pin depressed at the middle. pull it slowly for about 1/4 of an inch.
then you can remove the knob in the front of the timer switch.
in putting it back, install the knob first in the timer and then depressed that black plastic pin to lock the knob.
be carefull not to pull the plastic pin all the way out. it would be very hard to put it back in.
cheers,
drcool
Aug 02, 2008 | Frigidaire GLWS1339CS Top Load Washer
Removing Timer knob on Kenmore Electric dryer
Normally, to remove the timer knob, simply push in on the timer knob and turn the knob counter clockwise. it should unscrew itself. If it does not, the shaft inside the timer has broken and the shaft simply free wheels so then you need to take a needle nose pliers to hold the shaft and then you can turn the knob or pull it off
Let me know if you have any further questions
Jun 04, 2008 | Dryers
Timer knob
some models you remove center cap on knob and pull pin out others you need to remove screws in console and lean in forward to acess rear of timer push knob in pull small pin in back of timer and then pull knob off
May 21, 2008 | Maytag Performa PAV3200
Removing Timer Knob on Maytag MDE7400AYW dryer
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Mar 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Amana NAV5805A Top Load Washer Logo
741 people viewed this question
Top Amana Washing Machines Experts
Sal De
Mike
Gerry Harvey
Gerry Harvey
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
