Question about LG 42PG20 42 in. Plasma HDTV
I have a LG 42PG20D with a one inch brite white stripe, going from top to bottom about 3/4 along the screen on the right side
    President:
  • LG Master
  • 775 Answers
That vertical stripe is not fixable in plasma TVs.
Well, easily 99% of them.
The reason is that what goes bad is actually embedded in the display itself and not subject to servicing or replacement.
1% , possibly less, of the plasma TVs out there have that part outside of the display and as such subject to replacement.
Sorry for the new and please do not kill the messenger!
http://www.coppelltvrepair.com
Posted on Nov 24, 2013
SOURCE: I have a 42' LG plasma that has now has a 1 1/2
Own an DU42PX12XC that shows colorful vertical lines over half of the monitor, having only half visibility, sound is good.
Posted on Aug 30, 2009
SOURCE: Red Stripe, right side
Follow-up. I found the slip on which the LG tech wrote down the part number for the board to fix the vertical red stripe. I was mistaken in my previous post. It was not the Z-Drive board. The board you want is:
X DRIVE BOARD; Part 6871QRH043A
Type in the part number in a search engine and yuo will find multiple places to purchase. Ebay may be the cheapest. That's where I got another part which got my picture back. I did not buy this part myself because now that I have my picture back, I do not want to screw it up, so I live with the red stripe.
Posted on Jun 06, 2008
SOURCE: Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Posted on Nov 10, 2009
  • 418 Answers
SOURCE: i have a 1 year old 42 inch LG flat panel LCD and
Bad x-address board.
Posted on May 06, 2010
SOURCE: LG HD 37 INCH TV GREEN LINE APPEARING ALONG THE BOTTOM
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
Posted on Aug 07, 2010
There is a one inch white stripe on my 50" lg plasma tv. Any tips for a quick fix?
It seems to be a panel fault. Just visit this site and pull up older posts there to know more about symptoms of plasma panels fault. Illustrations are given. Compare with them to your screen's fault, and make it sure. surf the site by 'Timeslide' option, which can be selected from the drop-down menu at the top left of the display window. It will make search easy. Or type in the brand name to your set, in the search box at the top right.
Mar 31, 2013 | Televison & Video
My samsung 50 inch plasma tv has a black and white 2 inch stripe from top to bottom one third from the left side of tv our tv is about 1.2 years old is there a addjustment to be done ? thank you from mike
Image retention, Go to Menu and I believe pic settings go to the Burnin Scrolling feature..Will run white and black in full screen, run for an hour problem huold be solved..Happened to mine and the scrolling feature got rid of it.
Mar 15, 2011 | Samsung HP-R5072 50 in. Plasma HDTV
Yellow Stripe Down Middle of Screen on Laptop
This system has a VGA port so you can plug in an external monitor. You can buy one for less than $130 based on the Sunday ads. Other than that, it is new laptop time.
Jul 31, 2010 | Acer Computers & Internet
I have a 42' LG plasma that has now has a 1 1/2 inch verticle stripe on the right side. It used to come and go but now rarely goes away. Any ideas?
I believe that this could be a type of "burn in". If you watch anything with a black stripe on the sides or bottom of the screen often, then this could be the problem. My suggestion is to watch things that have no black side bars for a while (>week) and see if this eliminates the problem.
Good Luck!!
Jun 11, 2009 | LG 42PC3D 42 in. Plasma Television
Inch wide vertical white band on my Imac screen?
If the white band appears right from start up, the display needs to be replaced, if it comes on after it starts, it is most likely a software problem.
Feb 16, 2009 | Apple iMac G5 Desktop
HD Pavillion Media CenterDv8225nr Notebood Pc. Verticle stripes
I would try a couple of things. First and cheapest way is to try and update your driver. If that does not work, then try to remove and reseat your memory card(s), and if all else fails you will need to buy a new graphics card approx 75 to 150 depending on how good you want to go.
Feb 04, 2009 | IBM ThinkPad T21 Notebook
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Hi. i have an LG 42inch plasma, approx 18 months old. about 2 months ago, a green stripe developed down the right hand side of the screen, approx 1.5 inches wide. last week a 2nd stripe the same width...
Sadly, the plasma screen is failing. The green strip is no longer functioning properly and the failures will continue to progress.
If still under warranty, get it exchanged.
Jun 12, 2008 | Computers & Internet
Veritical bar in top right corner
PiP or bad connection. disconnect the set with all cables and reconnect and see what happens
Apr 06, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
LG 42PG20 42 in. Plasma HDTV Logo
101 people viewed this question
