My samsung syncmaster bx2031 will not turn on.
I know this monitor is less than a year old. Sometimes it turns right on with the computer. Other times it doesn't do anything. I tried to unplug cable going to the computer and only have the power cable plugged in and the monitor still won't turn on. It doesn't actually have a physical button. Only a sensor that is supposed to turn it on. Help!!!
SOURCE: My 19 samsung computer lcd monitor problem
I had the same problem...apparently the Syncmasters have some caps that are known to go bad pretty often. They will show visible swelling on the top with the slits. If they are flat they are probably good. The 820uF was too hard to find so I used a 1000uF with the same voltage. I had two caps blown on two different monitors so be sure to check them all. Hope this helps. Check out pics on BadCaps.com
Posted on Mar 31, 2009
SOURCE: Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Posted on Jun 09, 2009
najah
  • 180 Answers
SOURCE: difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Posted on Jun 28, 2009
  • 34 Answers
SOURCE: Syncmaster paower button blinking and no display
First of all plug another monitor to the VC on your PC and do the same for the SamSung"I over heat"SyncMaster2 053BW.
Oct 23, 2009 - This is how it went for me..I have a Samsung SYNCMASTER2.gif 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
HOW TO OPEN A SYNCMASTER 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.56ec44b.jpg
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for close to 6 hours with no glitches whatsoever. So I have resnapped mine back together. I hope you can too. - I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps.
Posted on Oct 24, 2009
  • 732 Answers
SOURCE: Samsung SyncMaster 940n monitor that turns on then goes black
rcpips, You may need to replace one or possibly 5 -8 aluminum can "electrolytic filter capacitors" on the "switch-mode-power-supply/CCFL inverter board. If, as you say "works for 5 or 6 seconds" then that means that fuse is good. Another thing you will need to inspect SMPS board for is "cold" "frosty looking" solder joints where the components (surface mount or through hole) are soldered to the copper circuit traces. May need large magnifying glass or low power inspection microscope to locate them. Resolder any that look bad or loose. Some solder joints have thinner than "hair" thermal fractures that can also cause YOUR TYPE OF SYMPTOM!! PARTS: digikey. mouser. newark. and possibly Radio Shack. If buying filter capacitors, make sure they are rated 105 deg C only!! NOT 85 deg C!!! If caps need to be replaced (swollen, leaky) be sure to tell us the brand name you find installed on your unit! CAPXON, ELITE, JUN-FU are just 3 that you don"t want to find in your unit. BAD news if you do!! If DIY suits you, remember to document with "close-up" digital stills your unit tear-down, so you can reassemble unit without any "extra" parts laying on kitchen table!! Filter capacitors are polarized. You put them in + to +, - to -!!! if you put them in backwards they go BOOOOMMM!!! Hope this helps a little. lmistyrel on aim or 12fixlouie at fixya.
Posted on Jan 30, 2010
Testimonial: "12fixlouie has been most helpful in helping me find a solution to my monitor problem."
Pink and Green Horizontal lines across screen
Normally, horizontal lines on an LCD or LED monitor indicate a bad control board inside the monitor. However, occasionally the problem can be caused by loose or bad cable connections. The only things that you can really do is to disconnect both ends of the monitor cable and reconnect them firmly. Also, you can disconnect the monitor cable completely and just leave the power cable. With only the power cable attached, you can turn the monitor on and off. The monitor should have a "startup screen" or display a message that says something like "Video Cable Disconnected". If the green and pink lines are still present without your computer connected, then the monitor has gone bad. The good news is that Samsung SyncMaster monitors usually carry a 3 year warranty, whereas most monitors only have a 1 year warranty. You may be able to have the monitor replaced at no cost to you if it's less than 3 years old.
Jul 27, 2013 | Samsung SyncMaster Computers & Internet
OUR sAMSUNG sYNCMASTER 205BW has a red tint in the background and cannot adjust it out.
The red or pink tint indicates that the back light florescent bulbs are failing. These bulbs are just like the bulbs in home and office lamps just much much smaller. When the reach the end of life the light output turns from pure white to red because the bulbs are not fully turning on. Check the manufacturer date on the back of the monitor, if its less than 3 years then the monitor is still under warranty. If its older than 3 years then its time to get a new monitor because your is about to fail.
I hope this helps, if so please rate my solution.
BuddyMc
Sep 15, 2011 | Samsung SyncMaster 205BW LCD Monitor
Good Morning, We've got a SAMSUNG sYNCMASTER bx2031, this morning all the detail on the screen went upside down -- help
There are some graphics cards that allow you to invert the screen. Don't worry, there is nothing wrong with your monitor. The following key combinations have worked for most people. Try it.
CTRL + ALT + UP ARROW (Try other directional arrows too) CTRL + SHIFT + R CTRL + SHIFT + 0 (Try other numbers too)
Hope this helps.
Apr 11, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Moritor turn off after 3 second
problem with power supply circuit or inverter and ccfl lamps..
May 17, 2010 | Samsung SyncMaster 920NW Monitor
The monitor is only 2 years old. less then 50
If you left it plugged into the outlet, the power supply is still running 24/7 even you never trun it on! Look inside for bad caps first, see example of failed SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | Samsung SyncMaster 932GW LCD Monitor
I have a Samsung SyncMaster 740N monitor has black screen, is very mild, very little. There is a way to increase the brightness or should I send it to repair?
eduardo_iros, Read more of my responses to others in my FIXYA profile so that you will know ALL the options you have to doing a repair or having someone else do it for you!! Follow all the links to other web sites and you will understand why your monitor has a problem with BLACK SCREEN or BLACK and BLANK SCREEN. Your monitor no different than any other CCFL backlit LCD display!!! It can be fixed (DIY) for less than $10 (sometimes) or for 4x that if you contract out the work! Good luck with the repair. 12fixlouie. READ, READ, READ before you do anything.
Jan 09, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Screen flickering on and off.
I have the same problem with mine. I've kinda narrowed it down to it being the power supply in the monitor. was told it is about a $20 fix but we'll see
Nov 16, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
My Syncmaster 205BW monitor has speckles & button's don't work.
Your monitor is defective. The speckles are actually dead pixels and the problems you're experiencing have to do with a defective board. Basically, it's dead, you need to replace it.
Jun 02, 2017 | Samsung SyncMaster 204B (Silver, Black)...
SyncMaster T200 won't respond after turning it off and back on.
i also got this problem..
do you have the switching anolog/digital thing?
that he doesnt know which he(t200) needs to pick?
Feb 05, 2009 | Samsung SyncMaster T200 LCD Monitor
Jan 30, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
