Question about Lexmark X4270 All-In-One InkJet Printer
I have installed a new black ink cartridge and it will not print the black ink. I have tried the cleaning but it still doesn't work.
    President:
  • 8,637 Answers
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
My desk jet 3320 printer do not print black
Are you sure there is enough level on the black ink cartridge.. if does try to do "print head clean up" if doesn't fix the problem consider to replace the black ink cartridge
Aug 31, 2012 | HP DeskJet 3320 InkJet Printer
Black is not printing
Try this to unclog printhead.
take out cartridge, locate the hole where ink goes trough, put a can of compressed air and blow it.
put some paper under the printhead to catch ink.
Jan 14, 2008 | HP Business Inkjet 1200dtn Printer
I have an HP Photosmart 2575 all-in-one printer, and my black is not working I just replaced it with a new cartridge and it still doesn't print the black.
The new ink-cartridge probably is OK.
So, start the HP Printing Assistant Software, and run the "Print-Head-Cleaning" utility, to run a few cycles. Hopefully, it will unclog the ink-jets that _should_ be spraying ink onto the paper.
Jul 25, 2011 | HP Office Equipment & Supplies
My eson xs 200 printer problem is not print black ink ol catush is new
perhaps this is can be help you....
1. try to cleaning head
2. remove the black cartridge only, (if it doesn,t changed after you cleaned head)
3. provide some warm/hot water on a bowl or plate.
4. enter the HEAD of black cartridge in to hot water. soak with depth about 2mm up to 5mm. while you see the ink is come out....
5. after the black ink has come out. pat dry with a paper towels/tissue.
6. replace the cartridge in to printer.
7. cleaning head again and print test page
good luck
Jun 19, 2011 | Office Equipment & Supplies
I have a Lexmark X6690 and bought new Lexmark print cartridges today - Black and Colour. The printer is recognising the colour cartridge but not the black one. Driving me nuts!! Please help x
Try to reseat the black cartridge. If that doesn't help, try to clean the cartridge nozzles. On the printer operator panel > press Setup button > Maintenance > Clean Cartridges > Ok. Your printer will then print a page, forcing ink through the nozzles to clean them. Try to print again. You may also try to insert a different known working black cartridge to determine if the other is faulty. If your new cartridge is faulty, return it to the purchase store (if within return period) or contact Lexmark technical support for assistance.
May 27, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
Black ink cartridge not empty, but won't print black...
Try running the cleaning tool included with the HP diagnostic software for your model printer. If that doesn't work, try cleaning the ink jets on the black cartridge directly with an alcohol swab. If this still doesn't work and you're sure that you have the correct model HP cartridge installed properly in the printer, you may have to replace the black cartridge with a new one to see if the cartridge itself is defective.
Oct 02, 2017 | HP PhotoSmart C4480 All-in-One Printer ...
The black ink cannot be
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed? Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred? Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If not, do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then there are other things we can try - assuming other solutions haven't worked either. Report back on my queries etc.
Feb 10, 2009 | Epson Stylus C43SX InkJet Printer
Colored Ink problem
Make sure you are using the correct cartridges for the Z35. They should be #26 (color) and #16 (black).
Make sure the contacts are clean where the cartridge connects to the printer electrically. A little alcohol wipe is good for this. Clean contacts on both the cartridge and the carrier in the printer.
Nov 19, 2007 | Lexmark Color Z35 InkJet
Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
Jan 19, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Lexmark X4270 All-In-One InkJet Printer Logo
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
