Question about Admiral AAV7000A
Pump pulley sleeve separated from pulling grinding on bottom
Can someone tell me how to fix this ASAP....can I fix it or do I have to replace it? Thanks bunches
  • 2 more comments
  • happilyevera Jan 06, 2009
    Problem resolved. Thanks.
  • Anonymous Feb 01, 2009
    I have the same exact issue and not sure if I need to replace the whole thing or not?
  • dkandjc14 Feb 15, 2009
    admiral washer starts to fill with water and then stops with a humming sound. Our basement had flooded somewhat, prior to this occuring. Could you help with fixing this? It fills with water and then will not drain or begin agitating. thanks
  • KENT6491 May 10, 2009
    I HAD THE SAME PROBLEM, i JHAD TO REPLACE THE PUMP($67)
    IBUT I BELIEVE IT WAS CAUSED BY THE TUB WOBBLING DURING THE SPIN CYCLES- I MAY HAVE A LOWER BEARING PROBLEM THAT CAUSES THE WOBBLE- THAT CAUSED THE PUMP TO GO BAD- CHECKED FOR LEVEL- CHECKED ALL THE SPRINGS-HOW DO YOU CHECK THE BOTTOM BEARING?
Egraber on FixYa hit the nail on the head on my previous post about my machine rattling during spin cycle. We are replacing the water pump today in which he also provided instructions on how to replace it! Thank egraber and thanks FixYa!
Posted on Jan 06, 2009
Pump or bearing problem?
If this is a top load maytag, the pump bearing sleeve will rub the pump pulley and make a grinding noise. Replace the pump.
Sep 26, 2013 | Maytag Washing Machines
Grinding noise during rinse cycles
This is what I would recommend doing. With the machine empty of water and clothes, and someone nearby to help, follow these steps.
1) Unplug the machine
2) Pull the machine away from the wall a good bit.
3) Lean the machine back, enough where you can lay down in front of it and have room to get underneath a little ways.Have the person standing by to hold the machine that way it doesn't have any possibility of falling on you.
4) With tha machine back, you can now see the three pulleys underneath, transmission ( located in the center, the biggest one), The motor ( located in the front right) and the pump located in the back.
5) Take the belt off by rolling it off.
6) Once you have the belt off turn each pulley. There should be minimum resistance when doing so. You may feel a little tug from the transmission pulley, but not from the motor and pump pulleys
I'm willing to bet the pump grinds or is hard to spin. If any of them pulleys are hard to turn, grind or anything like that the part is bad
Jun 05, 2012 | Admiral AAV7000A
We have a Maytag washing machine, model #HAV2460AWW, rev.10, serial #10359656CR. Just recently it started making a grinding noise that reminds me of a piece of wood jumping up and down against a bandsaw...
we just had the same problem and it was the bearing on the bottom of the pump, then it seized and we could possibly have to replace the motor to because of the load the bad pump put on it, I wish you luck with yours.
Jul 06, 2011 | Maytag HAV2557 Top Load Washer
Need to replace the main belt on the bottom of the washer. The belt goes around the drive pulley directly below the electric motor which is accessible from the front bottom access panel. The belt goes...
Unplug the motor wiring, remove the bolts holding the motor bracket (4 I think) remove the hoses from the pump and lift the motor and pump out. Remove the 3 screws on the pump and separate from the motor. Put the belt on the pulley and replace the pump. Slide the motor and pump back in with the belt attached, but don't put the 4 bolts on until you put the belt over the tub pulley. Then put them in and plug the wiring back onto the motor. That should do it!
Nov 20, 2010 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Washer wont spin
You may have some small piece of clothing stuck in the water pump. Pull clothes out, empty water out, turn over and remove pump and check for obstructions. If nothing in there see if it is frozen from moving, if not belt may be loose by being streched. Replace belt if needed.
Apr 16, 2010 | GE Spacemaker WSLP1100D Top Load Washer
Washing Machine staring making a grinding noise now it broken!
No, not the motor. The pump has a steel sleeve that has come up out of the pulley and has locked down the pump. Replace the pump and you will be fine.
Jan 27, 2010 | Maytag Atlantis MAV6000 Top Load Washer
The washer grinds while washing. This came out of the blue one load its good the next it sounds like its eating its self.
check the pulley on the pump they have a common thing of the pump pulley comming apart and grinding if not fixed it will melt the motor pulley and belt
Dec 31, 2009 | Maytag Atlantis MAV9501E Top Load Washer
Makes gringing noise when agitating does nat spin
The unit grinds and doesn't spin right ? Does it drain all the water out ?
The reason I ask about the spin is this. If hypothetically the pump had stones in it, or the bearings were worn, it would be grinding while washing (since it turns continuously, but only drains when the motor reverses) and could prevent the unit from draining sufficiently and hence, it will not spin.
**Unplug the unit from the wall**
Check the pump for obstructions, or worn bearing in the pump, you can check the pump fairly easy with the aid of a trouble light/flashlight on those, as the housing is usually transparent.
Remove the belt at the bottom. Lean the machine back against a wall or have someone steady it for you to do this. examine the pump pulley, it's the one in the rear right corner, when observing from the front. Turn it by hand and get a "feel" for if it's loose, grinding, or generally hard to turn. If you see the obstruction, pull off a hose from either the back access panel or remove the front panel, (the rear is easiest, the front gives more room) and remove the article/debris.
If that isn't the issue, let me know and we can follow up from there.
Good Luck
Oct 30, 2009 | Maytag Performa PAV3200
Makes grinding sound during wash cycle
Everything that grinds is saying.........stop using me and find out whats wrong before you use me again.
Could be gearbox or something stuck inside the machine.
Oct 24, 2009 | Maytag Performa PAV3200
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Admiral AAV7000A Logo
101 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
