Question about Canon PIXMA MX300 All-in-One Printer
Alarm = check printer 5100
Copier canon mx310 has an error messae of 5100. Turning it off does helpthe situation.
  • Anonymous Jan 11, 2009
    Thanks Chris for the advice, however, I have the same error message and my Canon is brand new, removed all the shipping materials and still have this 5100 - check printer. Help?
  • Anonymous Mar 17, 2014
    Printer menu shows Check Printer 5100 See manual
    Pls tell what problem for this?
  • 827 Answers
This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt or even some paper caught underneath the rollers that you have to jiggle around to even see. Check very thoroughly..
Hope this helps
Chris (ziraffa)
Posted on Jan 05, 2009
5100 check printer
Hello, your error is:
Carriage error [5100]
An error occurred in the carriage
encoder signal.
You need to disassemble the printer and check
- Carriage unit - check for any jam.
- Timing slit film - there should be some gresse on the film.
- Logic board - only if you are a service tech.
- Carriage motor - only if you are a service tech.
Nov 01, 2013 | Canon PIXMA MX310 All-In-One Printer
I cannot turn on the printer. The green light blinks; the alarm light blinks. "CHECK PRINTER" appears on the LCD with 5100 in the lower right corner. I checked all the connections; turned...
According to the Canon troubleshooting website here are the steps to follow for the PIXMA MX310 and Error Code 5100:
-Remove the cartridges
-Inspect the cartridges to ensure all packaging is removed
-Reinstall the cartridges
-Press the ON/OFF button for 2 seconds
-Unplug the printer and wait 10 seconds
-Check the printer for any obstructions including packaging materials
-Remove the scanner cover
-Open the lid - check for paper that is stuck; these can be very small pieces, so look carefully
-Plug the printer back in and power it on.
If that does not solve the problem you will have to contact a service repair centre. Good luck.. thanks
Sep 05, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 not complete printing, last sheet may have jambed, took out whole. alarm on; printer display says: Check Print, press OK get 5100 message. On/off reset, open close, checked for paper jamb,...
Before your printer is on press the paper feeder tightly and than press power printer. Don't release your paper feeder until your printer is completing task...... thanks
Aug 11, 2011 | Canon PIXMA MX310 All-In-One Printer
What does 5100 mean in canon mx310 series printer
There are several possibilities.
Have you changed out a ink cartridge lately? You can try and do a power reset by holding the power button for about 1 second until the machine powers down. You can also remove the power plug. Wait at least 30 seconds before turning the printer back on. Then wait for the printer to fully cycle before trying to print.
There are other possibilities. Let me know what has happened just before you saw this error code and I can give you more information.
Brian
Jan 22, 2011 | Canon PIXMA MX310 All-In-One Printer
The alarm button is on and 5100 is blinking on the screen, it will not print or scan or fax
Nov 17, 2010 | Canon PIXMA MX310 All-In-One Printer
I have an error - "cartridge jammed" pop up window advises to re
Please refer to Canon web site for specifics on resolving cartridge replacement and error 5100.
There's even pictures to help.
Apr 11, 2010 | Canon PIXMA MX310 All-In-One Printer
There are a error massage check printers 5100
Error 5100 on Canon's usually means there is an obstruction in the printing path stopping the paper feeding properly, or the clear film sensor the cartridges use may be dirty.
Check inside your printer for any foreign objects and also see if the clear film sensor is dirty. Clean with methylated spirits very gently if you have to.
Hope this helps.
Apr 03, 2010 | Canon PIXMA MX310 All-In-One Printer
The printer flashes on and off and the alarm is flashing and it says error 5100. So what is it?
Try the below website. It is especially for Canon.
http://www.fixyourownprinter.com/forums/inkjet/42085
Hope this helps and works as it has worked for many others too. I am one of them.
Feb 27, 2010 | Canon PIXMA MX310 All-In-One Printer
My cannon mx300 is giving me an alarm code 5100
5100 means either the carriage is not moving freely back and forth or there is grease or ink on the encoder strip. You can clean that clear plastic strip behind the carriage with a Q-tip, but also check on the right and left side for paper scraps stopping the carriage.
Nov 23, 2009 | Canon PIXMA MX310 All-In-One Printer
I'm setting up a PIXMA MX310 printer for the first time. After plugging it in and turning it on, it gives me a 5100 error.
I called 1-800-OK CANNON and got a great tech who figured out I'd neglected to take off some packing tape that was UNDER the LCD/control panel in the front—where the paper is loaded. Duh.
Aug 04, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX300 All-in-One Printer Logo
589 people viewed this question
old marine
old marine
