Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F-51 whirlpool error code cabrio - Whirlpool Cabrio WTW6600SBT Top Load Washer
SOURCE: whirlpool wtw6200 cabrio washer error message f 51
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Posted on Jan 01, 2009
  • 3 Answers
SOURCE: keep getting LD error code on whirlpool cabrio washer
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
Posted on Apr 05, 2009
jsrock516
  • 5911 Answers
SOURCE: Cabrio washer is giving an F 51 Code
The "F51" error code is common problem with the Cabrio. This is an RPS sensor error. The sensor is mounted along the motor windings under the washer and detects the rotation spin speed. The sensors on these units can go bad, causing the error code, and it has been a frequent problem. I would recommend you contact Whirlpool first (due to the unit only being a year old) and see if there is a recall or upgrade on this part. I believe there is. The repair would then be covered by the manufacturer. If I give you the steps to access and/or replace the sensor at this point, you may be voiding any existing warranty you may still have. Some components carry a longer warranty than your normal one year limited warranty from the manufacturer. Something you may consider.
If you have further questions, please let me know. I hope this helps you in some way.
Posted on Jun 11, 2009
  • 39 Answers
SOURCE: Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Posted on Jun 23, 2009
57 varieties
  • 1653 Answers
SOURCE: washer whirlpool cabrio message code f50,washer
F50 - This is a motor stalled failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Posted on Oct 02, 2009
Error code 51 f for whirlpool cabrio was machine
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Washer.
Mar 23, 2017 | Whirlpool Washing Machines
Whirlpool cabrio (model # WTW6600SW2) CODE F-51. WHAT IS WRONG
Thank you for contacting fixya.com.
This is a rotor position sensor error.Please check this link to know the resolution to the error code in the table given there:-
http://www.assuredparts.com/WhirlpoolCabrioWasherFaultCodes.html
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | Whirlpool Washing Machines
Help
F then 51 flashes when there is a motor rotor position sensor (RPS) failure.
It can also be a defective control board false reporting an error which is common on these models.
Apr 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code 51
there is a rotor position sensor failure.look under the top hood of washer on the inside of the front of washer and you will find a tech sheet that will help with this problem use a flat blade to push two clips in to get hood up.
Jan 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Jun 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio W10112999
http://www.theworldofwashers.com/2007/06/cabriooasis-f51-error-codes.html
F then 50 flashes when the motor rotor position sensor (RPS)
senses no rotation.
➔ Does basket turn freely? If not, determine cause of friction.
➔ If basket turns freely, see TEST #3, Page 10.
the above link is for code 51, very similar. the quite above is from the PDF manual. I just solved this problem on my machine. turned out it was clothing between the 2 baskets. Others have had bad control boards, or bad sensors
Oct 23, 2008 | Whirlpool Cabrio WTW6600SBK
Whirlpool Cabrio HE washing machine displays error code F51. What is it and hw to I fix it?
Jul 27, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
393 people viewed this question
Dan Webster
Dan Webster
Sal De
