Question about HP Photosmart C6180 All-In-One InkJet Printer
Pump Motor Stalled HP C6280 Photosmart
It also Ink system failure and I have put new ink in
SOURCE: i have a hp c6280
I had this same problem with my c6280.
I got fed up (HP only added frustration) and decided to trash it and buy something new.
So I figured I would take it apart and see if it was something obvious, worst thing that could happen was that the printer would not work - allready there.
Here is what I found.
Taking the covers off of this printer is not easy, but after removing all accessable screws I was able to get the covers off.
I found the pump motor on the left side of the printer (it is labled).
The pump motor has a large (approx 2 in) gear on it that is drivin by a belt with teeth.
The other end of the belt is drivin by a small (approx 3/8 in) gear.
There are two belt tensioners on each side of the belt.
PROBLEM; The belt was not riding on one of the tensioners.
This causes the belt to intermitenly engage the gears (stalled pump motor).
I put the belt back on the tensioner, put the covers back on (a real pain).
Printer now works fine.
I think that this may have been a problem out of the box because the lound clicking noise that came with the printer has also gone away.
Posted on May 06, 2009
  • 84 Answers
SOURCE: Ink System Failure on a HP Photosmart C6280 All-in One
This is likely a cartridge problem except if the carriage is not moving at all. If you still have some of the used cartridges you can used them to trouble shoot by elimination ok. Or contact a nearby technician who has the cartriges to use them for trouble shooting. I strongly believe the one of the print carts is the culprit. Good luck
Posted on Jun 02, 2009
  • 3 Answers
SOURCE: hp photosmart 3200 all in one ink system failure
I know this sounds crazy but I did this and others have too, it worked. Hold down four buttons at the same time ( OK, Cancel, Black , Color ) and turn the power off. Note: I figured out how to hold the 4 keys down with one hand and push the on/off switch at the same time. Once you power the printer back up is will take a few minutes to go through maintenance. Then it will “hopefully” go back to normal. I did this 2x’s. HP gives you a procedure that doesn't work! They just want to make money off fixing it every 6 months. They are in the service, repair and “ink business” not printer manufacturing.
Posted on Feb 06, 2010
pineworks
  • 4041 Answers
SOURCE: Ink system failure HP PhotosmartD7160
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
pineworks
  • 4041 Answers
SOURCE: HP Photosmart C6280 printer won't print and
Hi there
0xc18a0001.
Try the following steps to remove HP Printer Error Code 0xc18a0001.
I have put 3 ways for you to try.
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Or try 2
Turn the printer and wait until you receive the error message.
* Simultaneously press the keys "9" and "#" printer.
* While holding the button down, unplug the power cord from the unit.
* Wait a few seconds.
* Still holding the button down, reconnect the cable and turn on the printer.
* Release the buttons.
Or try 3
* Turn the printer and wait until you receive the error message.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Posted on Feb 10, 2010
Pump motor stalled hp C6280
may be inktube cut, pumping motor not working, or carriage assembly problem,
Mar 27, 2014 | HP Photosmart C6180 All-In-One InkJet...
What does "pump motor stalled"mean?
remove the cartridges, clicked okay. Then I waited for it ask for the cartridges, replaced them , that message concern with ink cartridge
and make sure you use the original supplies
Mar 24, 2013 | HP Photosmart C6280 Printer
Ink system failure
The below mentioned link might help you.
http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp/
Sep 21, 2010 | HP Photosmart C6280 Printer
What to do hp photosmart c1580 series ink system
hat to do hp photosmart c1580 series ink system failure Oxc18a0001
May 01, 2010 | HP Photosmart C6280 Printer
Ink system failure
The error is caused by air in your ink feed tubes. We have a guide posted on our web site at: www.ccl-la.com that will show you how to do a purge of the air and get back going. Look on the printer repair page and the the HP link. This will have to be done with a new set of ink cartridges.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 28, 2009 | HP Photosmart C6280 Printer
Our HP Photosmart C6280 All in One printer is giving me the Ink System Failure message, I have unplugged everything & taken out the ink cartridges & put them back in, same message...HELP!
Check out our web site at: www.ccl-la.com Click on the printer repair link, we have a section under HP that gives a step by step guide to fix your printer. The problem is caused by air in the ink feed tubes and the guide shows you how to purge the lines. You should be back printing in less than 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 25, 2009 | HP Photosmart C6280 Printer
HP Photosmart C6280 "Ink System Failure"
The ink failure error is caused by air in the ink feed tubes in your printer. This happens when the ink in your cartridge runs out and the printer sucks up air instead of ink. This is a very common problem with this series of printer. We have a step by step repair solution for this error posted on our web site at: www.ccl-la.com click on the printer repair pages and follow the links to your printer series.
I hope this helps, If so pleae rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 26, 2009 | HP Photosmart C6280 Printer
Jun 02, 2009 | HP Photosmart C6280 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
255 people viewed this question
Seeker5211
Seeker5211
