Question about Brother MFC 1970MC All-In-One InkJet Printer
How do you change the transmitting speed from 14,400 to 9600 ?
Hi I the brother MFC 1970 model. I need to know exactly how to change the transmission speed from 14,400 kbps to 9600 so i can send and receive a fax with comwave.ca with their Grandstream Modem. I am with Shaw Internet here in B.C. Canada and have a Linksys Router. I think i am all set to go, except for the changing of the speed to 9600. Apparently this is the required speed in order for all the 'packets' to be able to be transmitted and received. Can you help? Appreciate your answer. Thank You,
Kind Regards,
Nathan
  • nathan_wilho Jan 08, 2009
    Yes, Hi
    This is true, I also ended up contacting brother and there is no mechanism to change the baud rate from 14,400 to 9600 on this machine, so i had to use another one.
    Thanks Again for your help.
    Kind Regards,
    Nathan
    Genius:
  • 2,120 Answers
Fax machines are ANALOG devices, your fax will not work reliably on a DIGITAL phone line. There are no analog packets.
Posted on Jan 05, 2009
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Change baud rate for brother fax
  • Press Stop/Exit.
How do i change a speed dial number on my brother mfc-7340?
Changes to the contents stored in the address book do not become effective in the stored speed dial numbers in Windows®. Description:If you have made a change to the contents stored in the address book, the speed-dial is NOT automatically updated.
If you change the address book entry, please follow the steps below to store the speed dial number again.
  1. Click on the setup button to open the Brother PC-FAX Setup dialog box.
    Notes:
    You can also access the Brother PC-FAX Setup dialog box by clicking start => Programs => Brother => MFC-XXXX or MFC-XXXX LAN (where XXXX is your model name) => PC-FAX Sending => PC-FAX Setup.
  2. Click the Speed Dial tab.
  3. Select the Speed Dial No. which includes the member or group you made a change in the address book, and then click Clear.
  4. Click the Speed Dial No. you want to program.
  5. Click the member or group you want to store on the Speed Dial again and click Add.
  6. The Speed Dial is now registered with the new entry. Click OK.
If you put the patch below, the message that prompts you to confirm the destination number or address will appear when you send a fax using the speed dial. Also the message that indicates changes in the address book do not become effective in the stored speed dial numbers will appear when storing a speed dial.
  1. Make a temporary folder on your HDD [hard disk drive] as the location to save the downloaded self-extracting file, e.g. C:\brodnt
  2. Please click here to download the patch. (7.07MB)
  3. The Brother End-User License Agreement will appear. If you agree to the terms, click I ACCEPT.
  4. Download the file to the temporary folder created in Step 1.
  5. Once downloading is complete, open the folder and double click PCFAXUPD.EXE.
  6. The installation will start. Please follow the on-screen installation directions.
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Brother MFC 7420 All-In-One Laser Printer
My printer: brother model mfc 215c is not working.
Brother model MFC-215C is not working. It says: cleaninig impossible. Try trouble shooting and routine maintenanace. What can I do to solve this problem?
Jul 26, 2010 | Brother MFC 210C All-In-One InkJet Printer
No dial tone to fax documents with Brother Model
This issue was addressed previously by another FixYa expert. Read the entire post before attempting any repairs. Hope this helps
See:
http://www.fixya.com/support/t1234332-mfc_440_cn_out_memory
Dec 11, 2009 | Brother MultiFunction Center MFC-440CN...
How to change fax speed from14.4 to 9600
The machine does this automatically on connection. It negotiates a reliable connection speed with the recipient machine and then transmits data. If in encounters an error repeatedly it will negotiate the speed down even further until the data can be sent successfully. However the following menu setup option may help
Main MenuFaxSetup SendOverseas ModeOn will change the speed down to 9600 max and negotiate downwards if required.
Oct 30, 2009 | Brother Multi-Function Center MFC-240C...
Dont' Know Where Printer Cartridges Go In Brother MFC Printer
Here is the manual:
MFC240c Manual
See page 93 for ink cartridge replacement.
Thanks for using Fixya.
Jun 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
How do I connect?
You can use the Windows NT4 drivers located at http://www.brother.com/E-ftp/info/mfc/mfc970mc.html. Most likely you will need a parallel printer cable (D25 Male to C36 Male).
Feb 14, 2009 | Brother MFC-1970MC Plain Paper Inkjet Fax
Changing the transmission speed on my mfc-7420?
You can't change the transmission speed due to the system memory is not allow to do so.
Jan 20, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 1970MC All-In-One InkJet Printer Logo
149 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
