Question about Gigabyte Computers & Internet
Gigabyte motherboard 965p-dq6 driver pci simple communications controller
Driver not installef for pci simple communications controller
dlundmark
  • 797 Answers
SOURCE: pci simple communication controller driver
Hello fmjos:
Go to the motherboard's maker's site and download all information needed.
You must have the drivers for that mother board, and get them usually from the one who made it.
thanks,
Posted on Sep 02, 2008
SOURCE: pci simple communications controller
i cannot get the sound from the TV tunercard as the PCI simple communications controller in the device manager is showing yellow question mark
Posted on Feb 19, 2009
SOURCE: need a ethernet controller & pci simple communications controller
Try this link: http://partner.atheros.com/Drivers.aspx
You might be able to find something here.
Posted on May 18, 2009
  • 3278 Answers
SOURCE: Motherboard Simple PCI Communications Driver Code 28 for modem
Hello, Mike.
In case you still need this:
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware.
Hope this helps.
Posted on Dec 31, 2009
cspatiala
  • 54 Answers
SOURCE: PCI simple communication controller not installed.
First u have to install Microsoft Universal Audio Architecture .... that is UAA. then check in the device manager that is under system devices "pci bus" has excl. sign (i.e. ! ). Delete the pci bus device with exlc. sign. and press the button in the upper side of this window "scan for new hardware" it will automatically install the pci bus device and ur sound comes...
Posted on Jun 29, 2010
Bios not start.Only cd start but original bios not detected
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
if no luck
try removing the cmos battery although on some motherboards the cmos batteries are soldered in
which makes it hard or unlikely
hope this helps you
Oct 12, 2011 | Gigabyte GA-965P-DQ6 Motherboard
WHAT IS THE APPROPRIATE CPU FOR GIGABYTE GA-965P-DS3
This is a socket LPA 775 motherboard, it will accept almost all core 2 / quad core intel cpu's, here is the full list from gigabyte.
(you may need to unpate the bios for some CPU's)
http://ee.giga-byte.com/products/mb/cpulist/ga-965p-ds3_20.html
Sep 01, 2010 | Gigabyte 965P-DS3 (GA965PDS3) Motherboard
Hello, Mike.
Hope this helps.
Mar 29, 2009 | Gigabyte GA-7VA Motherboard
Gigabyte motherboard driver
The problem is not with *********** Board. Check the front panel audio connectors inside your CPU are connected to *********** Board properly.
Sep 28, 2008 | Gigabyte GA-N680SLI-DQ6 Motherboard
Raid
The RAID driver was supposed to be created by the Gigabyte CD on to a floppy disk. Durring windows you were to incert the floppy disk & press F6. Windows would have included the driver software. You can also go to Gigabytes web site & download the RAID driver. (This site is for rev 2.0).
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=2422
For help instruction on how to setup a RAID configuration. Read through this link.
http://www.pcstats.com/articleview.cfm?articleid=830&page=6
& this link will also help.
http://www.pctechguide.com/tutorials/RAID.htm.
Read pages 65 to 75 for RAID setup in manual.
The links online will help you understand setting up a RAID system.
Good Luck! & Take you're time.
Mike
Jul 07, 2008 | Intel Motherboard
Usb fault
Did you run the motherboard cd? The usb drivers are on it. Also, make sure they are enabled intthe BIOS.
Please let me know how this works for you.
thanks
Feb 08, 2008 | Gigabyte GA-965P-DS3 (0818313003027)...
PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Dec 07, 2007 | Gigabyte GA-7VT600 1394 Motherboard
Open Questions:
Computers & Internet Logo
42 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
