Question about Whirlpool Dishwashers
WHIRLPOOL DISHWASHER GU940SCGB3 WONT DRAIN
PUMP MOTOR RUNS WONT DRAIN NO CLOGS
SOURCE: Bosch SHV 4303 Dishwasher not draining
I have a Bosch Classixx with what sounds the same problem.It would not drain properly and hummed even when the front door was opened.After a couple of days it ponged a bit.This is what I did.Sypnoned off yukky water with a short length of hose (fill pipe with water from tap don't **** on it!!).Cleaned filter under cutlery tray at bottom.Then put a TEASPOON of bleach if on main drainage or dishwasher cleaner if septic tank.Ran on a hot wash and see if it sorted problem-it didn't but did clean system.
Syphoned off again -take care.Isolated electric and water supply.-Should do that first perhaps Pulled out from under counter undid drain hose at sink end and water at machine end.I then put machine on side and undid bottom silver plate.Note position of polystyrene float switch cover.I then followed drain hose to drain pump and undid it by twisting it like a bayonet light bulb undoing clip levering with screwdriver (not for feint hearted as easy to break) -I then checked little impeller for foreign object-found none so pulled off pump housing by rubber hose to bigger pump thing next to it and found small bit of plastic put it back together and hey presto problem sorted-I was told it might take two hours for the expert to do it once on his workhop bench-it took me about 30 mins plus a bit of head scratching and a yank and push or two which could have been rather expensive -I was lucky!
Posted on Aug 24, 2008
rylee_smith
  • 8619 Answers
SOURCE: Have new Hotoint dishwasher that wont drain. Drain not clogged !?
Hi
If the water doesn't drain from your dishwasher, check these: Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain line/air gap Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as "FixYa" if found useful and revert for further assitance.
Thanks
Rylee
Posted on Apr 05, 2009
SOURCE: Whirlpool Quiet Partner II Dishwasher
rw2fanru quiet partner IV wont drain water
Posted on May 10, 2009
  • 7 Answers
SOURCE: The drain pump motor on my ASKO model 1375
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Posted on Sep 01, 2009
  • 530 Answers
SOURCE: Kenmore (Whirlpool) 655 1589910 Dishwasher.
you need to clean/ check the chopper. sounds like you have a bad motor. about 2-300 dollars for the part
Posted on Dec 23, 2009
Why wont the water empty out?
Sounds like an electrical control problem, or bad connections or a bad pump and or motor. Otherwise a clog in the Dishwasher drain hose, or even the connection to sink drain is clogged.
Mar 04, 2015 | Whirlpool WDF510PAYS Dishwasher with...
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
Wont drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
Apr 17, 2011 | Whirlpool GU2800XTVS Builtin Dishwasher
Does not drain even though it is not clogged
How do you know it's not clogged in the pipe/pump/outlet?
There can be several issues with this. If the pipe for the dishwasher is installed wrong, there may not be enough back pressure for the drain pump. See your install instructions.
The drain solenoid may not be functioning. (Listen for a sudden 'Thunk' when the dish washer hits the drain cycle). It may not have a solenoid.
The pump should be running if the dishes get washed.
There is a back flow valve at the drain hose outlet on the pump. Is it jammed/clogged?
The worst is a failure of the pump impeller or diverter. This means a motor.
Mar 21, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Wont drain
check to see if anything is clogged inside the drain line, if not the pump motor assembly must be changes out, some had five yr warrantys check ur manual, usually cost for pump motors are 200-400 so it might be cost effective to buy new if u undo the drain liine and cant locate a clog or remove debri from inside,, u can try to remove stuff from the pumo if u can remove the components from inside middle.. hope this helps
Feb 06, 2010 | Whirlpool Dishwashers
Whirlpool Dishwasher (DU800CWDB1)does not drain. Have taken everything apart, cleaned, tested.. same problem.
If you have cleaned the pump and outlet hose and it still wont work, Have you checked that the drain it is connected to is not pluged up ? Is the motor running during the time it should be draining out ? The way they work is one direction for wash and reversing for pumping out.
Nov 07, 2009 | Whirlpool 24 in. DU800CWD Built-in...
Whirlpool DU960PWKQ1 Dishwasher will not drain completely
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jul 24, 2009 | Whirlpool DU960PW Dishwasher
Dishwasher wont drain
HI, usually, if the dishwasher dose not drain properly, it will be the fault of a defective or, malfunctioning pump. i will list several problem areas to check. Inspect each area properly and, replace any component that is faulty or fouled.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Mar 09, 2009 | Whirlpool DU930PWS Built-in Dishwasher
Dishwashers Logo
65 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
