Question about HP Office Equipment & Supplies
Hp psc 4622 error 388
Fax failed
  • 16 Answers
SOURCE: error message
Try to send the fax at a different time when telephone line conditions have improved.
Or try to disable the ECM on yuor printer, to do that to these steps:
Press SETUP
Press DOWN until you ADVANCE FAX SETUP displays
Press OK
Press DOWN until ERROR CORRECTION MODE displays
Press OK
Press RIGHT ARROW to turn it off
Press OK
Then try to send new fax. If this does not resolved your issue pls try to go to your phone provider. Thanks
Posted on Jan 05, 2008
Riztech
  • 731 Answers
SOURCE: Fax Error codes
I have mentioned the Description for the error codes.388 and 421 error codes means the same and suggestion to resolve the problem.
282 - Retry the transmission.
388 - Reattempt the fax reception at a different time when telephone line conditions have improved.
421 - Reattempt the fax reception at a different time when telephone line conditions have improved.
233 - A communication failure has occurred between the two machines (OR) The user at the remote machine might have pressed the Stop button. (OR) Sometime Call waiting service might cause this error code.
  • Turn OFF the Error Correction mode(ECM).Steps to do. Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to Error Correction mode(ECM) and highlight -> press ok/Enter->Select turn OFF-> press ok/Enter.At Last Press Cancel to quit the menu.
  • Decrease the Fax speed.Steps to do.Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to" Fax speed"-> press ok/Enter-> Choose "Medium speed or slow speed ->press ok/Enter. At Last Press Cancel to quit the menu.
Thank You
Posted on Feb 09, 2008
  • 5 Answers
SOURCE: Error 232 receiving fax
fax error 232 indicates a communication failure between the sending and receiving units. I'd check for line noise on the phone (you can hear it as cracks and pops) If your fax line is not dedicated, any noise from another phone pickup or an answwering machine can cause the failure.
Posted on Sep 08, 2008
SOURCE: fax not working Error 388
We had the exact same problem. Static on the line. We had the cable company check and sure enough our digital modem for the phone line was bad. The new replacement fixed the problem instantly.
Posted on Jan 23, 2009
laxmankumar
  • 191 Answers
SOURCE: Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
Posted on May 23, 2009
Error code 388
Solution
Sep 09, 2013 | HP FAX 1250 Fax Machine (Black)
Hp laser jet m1536dnf MFP won't send fax comm error 388
You can start by making sure that the photocopy is working, this is to ensure that the scanner is working. Next, try to isolate the issue if this is only happening to only one fax number? If all of these have negative results, I suggest for a hardware reset. Follow the steps for reset found here, How to Reset the HP LaserJet Pro M1536dnf Multifunction Printer. Goodluck :)
Aug 14, 2012 | HP PSC 2410 All-In-One InkJet Printer
Fax Error 388
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395Definition
Solution
Oct 07, 2011 | HP Photosmart Premium C309A All-In-One...
Keep gettomg error message 388
Hi There,
HP Support provides definitions and solutions for it's printers.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=buu02549#Error386
At this site you can simply scroll down and click on the blue underlined link "388" which states,
"There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time."
"Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve."
Since you didn't state that you were having a problem sending faxes, I fear this is limit to which I can assist you. That being the case, please reserve negative feedback for HP if the solution isn't sufficient.
If the error persistes and you are not attempting to send a fax unsuccessfully, it would indicate a false error report and that your registry in your operating is a bit out of order where the printer is concerned and the best "final" solution would be to uninstall the printer from the Control Panel COMPLETELY, then hold down the WIndows logo key and press the R key. A Run window will appear. Type in %temp% and hit ENTER. Your Temp File folder's contents will appear. Left click one in that window and then hold down the CTRL key and hit the A key. All files will be selected. Hit the Delete key. Remove every file that Windows will allow and then close the window, Disconnect the printer from your computer. Then go here:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=Officejet+6210
Select the correct version of your 6210 (there are 3). At the next page Download the Full Version software by saving it to your Desktop. Then double-click the software installation file and follow the prompts. Do not connect your printer until the software prompts you to do so.
Ciao for Now
Solution
Solution
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Sep 07, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My hp4225 do not sent or receive fax messages, error 388*
hiii
well this error generally arises when there is too much of disturbance in the line.It may going away with time.And if it doesn't then u must retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Sep 03, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Solution
Solution
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 4315
HP Support Web page
<http://tinyurl.com/lbwcwd>
Error Code:
Solution
Apr 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
When trying to fax connects ok but comes back failed error 388
A list of HP aio error codes:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You could try running the Fax test. Press setup > Tool> Run Fax test.
This will give you instructions about what you need to check and what you need to do if it failed on some of the tests.
Then try to send a fax to the HP fax test server detailed below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00259105&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Jan 19, 2009 | HP Photosmart 2410 All-In-One InkJet...
Sending faxes
Error 388 is for telephone line conditions being bad, have you called your telephone company and head you telephone line checked...?
If not please have it checked.
For more details on the error message check the link bellow with Error codes any their reasons:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&lc=en&dlc=en&product=79477
Good Luck
Oct 11, 2008 | HP PSC 2410 All-In-One InkJet Printer
Fax
error code 388 says :-
Unable to complete the handshake.
*Try to send the fax at a different time when telephone line conditions have improved.
Mar 06, 2008 | HP PSC 2410 All-In-One InkJet Printer
37 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
