Question about XO Vision X349NT Car Video Player
On a xo vision x349nt how do i set my in dash to turn on my amp with subwoofer
SOURCE: XO Vision XOD1740BT in dash dvd player bypass code
I solved it By connecting the pink wire to a constant ground this acts as a bypass so the unit plays anytime.
Posted on Dec 17, 2007
dj x
  • 61 Answers
SOURCE: xo vision dvd player
hi there
it shouldn't be to hard to install this but it does require cutting a hole in your interior part of roof........a install like this could take anywhere from 30 mins - 1hr for a installer to put it in. to do it yourself it could take 1-3hrs to complete (note for your first time doing this take your time and follow the install manual that will be provided)
Posted on Mar 06, 2009
  • 3 Answers
SOURCE: help me with back up camera for xo vision xod1740bt
I am just giving a suggestion. I too need to know how to wire this. From what you posted it sounds like you hooked the wire to a constant +12v that is always on. Forgive me if I am wrong. Anyway, Did you connect this wire to rear reverse light power. I think from what you say it is supposed to be connected to the positive side of that light. If this solves your problem can you PLEASE let me know the full details of everything else you hooked up on the circuit to make the backup work. For instance what is the label of the orange wire. TIA.
Posted on Apr 06, 2009
emissionwiz
  • 80339 Answers
SOURCE: is there an adaptor to receive the digital tv
the analog to digital converters are for home based TV systems not mobile, you can try contacting the maker of the unit and seeing if they have a solution for you
Posted on Aug 14, 2009
SOURCE: replacement screen for xo vision 1742 deck
Model LCD 7'' :Innolux AT070TN07 + Touch panel (unknow)
Posted on Apr 28, 2010
My RCA cables aren't working...
try pressing in on the left large button
Dec 04, 2017 | XO Vision X349NT Car Video Player
I just installed a new xo vision x349nt dvd receiver in my car . My rockford fosgate p3001 amp turns on but the subs doesnt come on but when i would take the base control out and put it back in i can hear...
Make sure and check the RCA wires in the back of your radio that send audio to the amp and make sure that they're connected to the OUTPUT/SUBS RCA's and not an input rca's. Also, check your ground and make sure no speaker wires in the subs are shorted. Try one speaker at a time see if that helps.
May 18, 2011 | Rockford Fosgate P3001 Car Audio Amplifier
Subwoofer out put there is 1 i have 2 rcas
Get RCA "Y" connector, radioshack, etc.
Or, plug your 1 RCA into the amp and wire to sub from amp
Oct 09, 2009 | XO Vision XOD1735 Car DVD Player
Does the xo vision avs 444 need a power source? and how do i power it up?
i CANNOT FIND THAT MODEL !! Is it an in dash stereo ? Or an external accesory ? XO makes SOO many different things that I need more info. Unless its a stereo unit that goes into your dash, for that you will need to go buy a clip that takes the stereos wires and turns them into the plugin for you factory stereo hole. (EG- Canadian tire, about $15 for most cars.)
Aug 16, 2009 | XO Vision Car Audio & Video
I have all the wires running right but for some reason my amp is not picking up or pushing my subs. could the rca jacks be messed up on the stereo?
According to the specs for the xo 1945- the output is; 50W x 4 Max Power Output , and I do not see a pre amp output listed. So I think to connect subs, you will need a separate AMP.
The way this works; the rear speaker wires from the xo 1945 hook into the Add-on amp, for example a 4 channel amp. In a 4 channel amp, the rear speakers come off two of the channels of the add-on, and the subs come off the other two channels. There is also the option of bridging two channels for more output power to ONE sub.
You did not mention what size sub(s) you were thinking of adding, but keep in mind that the ox 1945 puts 50 watts MAX per channel. So, if you add two 12" subs and a 1500 watt amp to drive them, your total sound is going to be very uneven.
If you go on line and look up auto audio or amps, you'll get a good idea of all the Sub and amp options that are available.... Hope this helps.
May 02, 2009 | Car Audio & Video
No sound
You need to buy an amp adapter. SCOSCHE OEA4 4-Channel Adjustable Factory Amplifier Int. 23 bucks on ebay. You most likely have a factory amp in your car and the head unit's speaker output wires are already amped. the factory amp can't understand the audio signal.
Dec 01, 2008 | XO Vision XOD1735 Car DVD Player
XO Vision Bluetooth in-dash dvd player
you probably set the audio for 5-channel. In a 5-channel set up. Which it doesnt sound like you have there is a 5th speaker in the center of the dash dedicated for clear vocals. Play with surround options and i'll bet you can fix it
Dec 21, 2007 | XO Vision GX733 7.3 in. Car Monitor
Dec 15, 2007 | XO Vision XO-1400 Car DVD Player
XO Vision X349NT Car Video Player Logo
26 people viewed this question
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
