Question about KitchenAid 24 in. KUDP02CR Built-in Dishwasher
Too much current
Hot wiring harness seem to be all wires. Two solenoids burnt out, the soap dispenser and the vent in door. One transister lead burnt off near the soap dispenser connection. Have replaced the dispenser lost it first time. Seems to run through all cycles ok. Don't know when to open soap door manually. Bought new June 2006. Thank You! Jack
  • kinzsammo Feb 06, 2009
    Soap dish uses a solenoid to open the door for the soap, durning the wash cycle. This same solenoid is used during the rinse cycle to add rinse aid. I've replaced the soap dish twice and each time the soleniod burnt out.
    Sergeant:
  • 326 Answers
Bi-Metal Switch
A bi-metal switch is an electrical component made with two pieces of pliable metal located behind the dishwasher detergent cup. When an electrical circuit is sent to the bi-metal switch, the pieces of metal expand, disengaging the dispenser's door. A defective bi-metal switch will not expand enough to disengage the detergent door. Test your bi-metal switch. If it is defective, you will have to replace it.
SOME DISHWASHERS HAVE A DRAIN VALVE ACTIVATED BY A SOLENOID. CHECK FOR VOLTAGE AT THE SOLENOID.
NO VOLTAGE, CHECK THE CONTROL. IF VOLTAGE IS PRESENT BUT THE SOLENOID IS NOT ACTIVATED, REPLACE SOLENOID.
solenoid burnt up on you, Unplug dishwasher take four screws off lower panel looking under to the left on the front side of the pump and motor assembly you should see the drain solenoid see if it moves with a down motion and pops up again if not you need one. also if it looks melted Dishwasher drain solenoid kit Item # 271344 Price $31.50http://www.repairclinic.com/referral.asp?R=154&N=271344
Depends on why the valve toasted. Internal leak onto the copper winding or the timer sticking. I'd look for signs of leaking around the valve
Posted on Feb 06, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Other than high current, another cause for heating would be a loose connection. The loose connection offers a relatively low resistance which then causes the heat built up on the junction of connector/terminal. The heat is transferred to the wire/harness. One solution is to clean/scrape and tighten the connectors by slightly crimping them that they offer a more positive contact with the terminals.
This would require checking the connectors over, look for discoloration of the terminals/connectors and even burnt marks or even deformed plastic connector holder. Often heating up starts from the ends of the harness and travel along the wire.
Good luck and thank you for using FixYa.
    Genius:
  • 1,036 Answers
Please check te power supply unit and see what it is rated at - 240 or 220 or 120 ?
If it is possible to confuse things - it seems likely.
Power supply should be checked first.
If wires and solenoids are burnt. This is likely to be the main culprit.
If the control board is damaged, it should be replaced unless you can trace the problem to a damaged large resistor before the burnt resistor.
    Sergeant:
    Scholar:
  • 199 Answers
Many dishwashers ( but not all ) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost it's ability to bend properly and needs to be replaced
Posted on Jan 05, 2009
    Genius:
  • 1,268 Answers
Try to look for the screws at the side of the soap door. You can try to remove it and check if you can remove the soap door.
Dishwasher won't access soap tray
Check if the dish rack is reversed. If it is, it'll block the dispenser from opening.
If that is not the case - you may have problems with soap dispencer solenoid or with control board. Unplug the d/w. Disassemble the door, and find the solenoid contacts on the dispenser. Check for continuity. No continuity - replace dispenser.If dispenser is ok, check wiring for continuity. Otherwise it's the board.
Jun 01, 2010 | Dishwashers
My soap dispensor won't open during the cycle
at times soap contaminates the electrical connections at the door latch connector and the timer pins.check the wiring Accumulated detergent and other material can interfere with the spring mechanism or halt the pivot action of the door. Use very hot water and a micro-sized brush. You also can use a mix of hot water and vinegar.Most dispensers have a bimetallic strip or switch, attached by screws, which triggers the door release. With the front door panel removed, locate the switch, and push on it gently with a screwdriver until the dispenser door opens. You might simply need to adjust the alignment of the switch.
you will need to open the assembly if you are skilled.if the problem persists after this then Most likely the soap dispenser assembly has to be replaced..hope this helps
Jan 13, 2010 | Thermador DWU244 Dishwasher
KITCHEN AID STAINLESS DISHWASHER MODEL #kuds02frssWe just replaced both springs in the door and the latch mechanism and the soap dispenser that still does not work. Our door will not stay shut. MY HUSBAND...
Hi.
Your husband must check wiring harness from electronic control to door lock solenoid.
The solenoid should also be tested reading Ohms with a multimeter.
Here parts and diagrams: KUDS02FRSS
Dec 02, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
The some dispenser and the rinse aid dispenser seem to be "stuck", soap door doesnt open and dishes appear streaky from no rinse aid. this happened after I cleaned the deposits from under the screen in the...
There is a solenoid which pops open the soap lid after the initial rinse.
If the solenoid or soap lid latch is faulty, you will need to replace it. In the interim just poar your soap in the bottom of the dishwasher tray before cycle starts.
Only use a little amount as per normal. Dishwashing tablets are best as it is a measured amount and has the rinse aid built in.
Good luck.
Ash
Oct 21, 2009 | Bosch Dishwashers
During dishwasher cycle soap dispenser won't open. at the end the soap tab is lying on the floor of the dishwasher.
Remove the door inner panel and check the dispenser door solenoid for free movement along with the latch mechanism. Water can enter through a leaking seal and corrode the interior of the solenoid causing sluggish or non-functioning of the latch. Change the solenoid if it seems sticky and can't be fixed by cleaning the bore and plunger (don't apply oil as it will gum up the operation after a while).
Oct 18, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Whirlpool dishwasher DU840SWP. soap dispenser not opening during cycle
Does the washer heat the water during the hot cycle. If it does, your soap dispenser module in the door is faulty. To install, you need to pull power plug out first,then sit on a chair in front of the door and then open the door towards yourself. Once open unscrew those screws along the perimeter of the door to enable you to remove outer panel. Once off, you can view how to remove soap dispenser. If water does not get hot, check the heater element and/or the reset (over temperature switch). Note, top rotator must move freely as well to allow hot water dispersion which on some occasions activates the soap dish. On other occasions it uses a solenoid switch.
Oct 03, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
How do we replace soap dispenser for Bosch SGS5302GB/07
Unplug the unit. Open the DW door .remove screws.Carefully place it aside. you are going to see soap dispenser unit. remove the wire harness carefully, remove the screws. Replaced it with new one. so simple. assemble back the door panel.
Jul 23, 2008 | Bosch Dishwashers
Soap dispenser
It sounds like the soap dispenser flap is stuck or the latch is broken. Try to see if it can be manually opened to loosen it. How long do you wait before starting the dishwasher after the soap is placed in the dispenser? Check and see if the cover opens even a little during the wash cycle?
There could be a problem with the solenoid that opens the soap dispenser. I don't know of the part number for this. You'd have to call Bosch or check their website.
Mike
Jan 25, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Soap door won't open during wash cycle
IT SEEMS YOU SOAP DOOR HAS A BAD SOLENOID ACUATOR OR RELAY
Jan 17, 2008 | Kenmore 24 in. 16592 Built-in Dishwasher
Soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
Jan 16, 2008 | Maytag 24 in. PDC3600A Built-in Dishwasher
KitchenAid 24 in. KUDP02CR Built-in Dishwasher Logo
35 people viewed this question
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
