Question about SanDisk Sansa e260 MP3 Player
White screen only on E260 4 GB-cannot get to the menu or anything
Hi-
On the E series players, how do you turn the volume up?
I see the normal and high but the sound itself is not adjustable.
We are trying to play it in an air hockey arcade game, just plugs into the unit-I can hear the music but
Very very low, not enough to know what song is even playing.
Another question on the 4 GB (My daughters).
She had it charged all day, but the screen is all “white”.
Totally white, pressing all the buttons does not change the screen at all.
Completely white, I cannot get the sansa menu to appear at all.
Her unit iwas purchased end of Dember 2006.
Could this just be replacing the battery fix?
Thank-you for your help on this.
Colleen Paige
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
Adjust the volume while playing by "turning" the thumbwheel. Go clockwise to increase, counterclockwise to decrease.
Posted on Jan 11, 2012
  • kakima Jan 11, 2012
    To reset the player, hold the power button for fifteen seconds.
SOURCE: Frozen sansa e260
you should just leave the power button pressed for 10-15 sec.and it should turn off
Posted on Jan 01, 2008
monopogo77
SOURCE: computer(s) wont recognize sansa e260
i have the same SANSA e260.....and the same problem....its easy just turn on your sansa then push the menu botton, slide the wheel in the center and at the end of the options say USB enter there and change usb mode from MTP to MSC mode.....and ready
Posted on Jan 03, 2009
kram26
  • 544 Answers
SOURCE: I need to know the maximum GB external micro sd
thank you for choosing Fixya.com
you can use 4GB it is the applicable memory on your mp3.
if you will try to use much higher than 4gb sometimes it is the reason why our player are hanging up.
please don't forget to rate our answers properly.
Posted on Mar 05, 2009
  • 17 Answers
SOURCE: Sandisk Sansa e260 Software Needed!
You can go to the sandisk website and click on support then downloads. Then select your product. Here is a quick link to the downloads page. This is for the drivers and firmware update. Hope this helps you. http://www.sandisk.com/DriverDownload/index.asp
Posted on Mar 08, 2009
ah1f39
  • 34 Answers
SOURCE: I cannot add videos to my sansa e260 4 GB media player
Are you syncing the videos through Sansa Media Converter? This is the only program that will work to put video on the E200 series Sansa's.
If you are using SMC try using "Any Video Converter" to make the mp4's then sync them through SMC.
http://www.sansaworldmp3.com/
http://www.sansaworld.com/
Posted on Apr 05, 2009
When I turn it on the screen turns white. The
When I turn it on the screen turns white. The screen is all screwed up. I can still listen to music, I just can't see the menu or tell what anything says
Jul 08, 2010 | Philips GoGear ViBE Digital Media Player
Ipod touch 2 gb screen went white
that happens sometimes. whenever it happens, hold the power and home button until it turns off. then turn it back on
Mar 25, 2009 | Apple iPod touch
Ipod nano volume control
Try
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Jan 26, 2009 | Apple iPod nano 4th Generation
My ipod 30 GB is showing only white screen
Most probably restoring should help ..... Restore with itunes....
Oct 12, 2008 | Apple iPod MA446LL/A MP3 Player
White Screen??
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 03, 2008 | Samsung YP-K3 MP3 Player
Cant hear anything
Try different headphones, see if they work. Also, go into the audio settings menu, and make sure all of the audio settings are kosher.
As for the Invion...it is normal for an mp3 player to do "something" when you unplug it from computer - turn on, update, turn off when you disconnect it from computer, etc. It is not normal for you to get power ONLY when you are connected to computer. After disconnecting from computer, try turning the mp3 player back on - does it turn on? Make sure it is fully charged, of course.
If it won't turn on outside of plugging it into computer, then hold in the volume + button before you reconnect it to computer and continue holding it for 10-30 seconds after reconnecting - Windows will try to reload any missing drivers/software. If the problem persists, I would find out if your mp3 player is still in warranty, b/c it will need to be replaced.
May 14, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Screen Troubles
Sounds like the LCD controller has gone bad - must be replaced.
Try every "soft fix" first to be sure:
*Reset - button on side
*Firmware Upgrade (sounds like you tried it)
*Reformat the player -p.68 of manual - available on iRiver website if lost - enter model as H300 series
*Recovery -
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Jan 11, 2008 | iRiver H340 MP3 Player
My c250 turns on, but not in the way I would like it.
Try a hard RESET by holding the POWER and the MENU for about 15 to 20 seconds. That may reset the player back to the factory settings.
Jan 07, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
IRiver screen appears but no menu
Oct 19, 2007 | iRiver H10 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
143 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
